Author Topic: Help identify this component?  (Read 3074 times)
Offline BladeDreamsTopic starter
« on: January 13, 2014, 12:41:55 am »
Hello!
New here....that said....
Can anyone help Identify this component?
It's out of a Philips FR968/17 home theater system, this is on the main board - part number 3927.
I thought it was a resistor, but i am unable to find any similar to this one.
(yes there are 2 that are "smoked" - I will be replacing all 4...I hope!)
As this is a very basic, very simple through hole design one sided - figured it would be simple to fix...
Well, the replacement is very easy - I just need a part - LOL. Or a compatible replacement.
Thanks in advance!
Online xrunner
  • hp>Agilent>Keysight>???
Re: Help identify this component?
« Reply #1 on: January 13, 2014, 12:48:20 am »
What makes you think it isn't a resistor? Did you measure the other ones that aren't burned with an ohmmeter?
Edit: Looks like a 4 band color code -
22 * 0.01 = 0.22 ohms(5% tolerance)
« Last Edit: January 13, 2014, 12:53:45 am by xrunner »
« Reply #2 on: January 13, 2014, 12:54:53 am »
only reason i im not sure is I cannot find any matching this.
looks to be .77ohms.
Bands are violet, violet, silver, gold.
testing those next to it now...
Offline c4757p
  • adieu
« Reply #3 on: January 13, 2014, 12:55:47 am »
I see red, red, silver, gold. 0R22 5%, looks like 1W, possibly fusible.
Online xrunner
« Reply #4 on: January 13, 2014, 12:56:17 am »
Yea OK the colors didn't come out here very well.  :)
Offline rdl
« Reply #5 on: January 13, 2014, 12:58:36 am »
There are pink resistors, but those color code bands are weird. The fact that there are four of them and mounted way above the board surface makes me want to guess that they could be diodes being used as a rectifier.
Offline c4757p
  • adieu
« Reply #6 on: January 13, 2014, 01:00:03 am »
Nope.
Resistors.
0R22.
Haven't you guys ever seen a hard-to-read resistor before? Must be just me who gets the crappy ones all the time...
« Reply #7 on: January 13, 2014, 01:01:14 am »
So, you see my issue.
I looked up .22 ohm ones - none look like these - but I can find the values.
looked up .77 - Nothing.
As to being something else - LOL thats what Im asking. :-//
« Reply #8 on: January 13, 2014, 01:03:50 am »
You may be right - found this -
http://www.ebay.co.uk/itm/5x-0-22-ohm-0R22-0-22R-1W-1-Watt-Metal-Film-Resistor-/200641154286
I will have to go more on the 0R22 hunt....
Thank you ! :-+
« Last Edit: January 13, 2014, 01:12:10 am by BladeDreams »
Online xrunner
« Reply #9 on: January 13, 2014, 01:06:34 am »
Thank you ! :-+
Well there you go.  :)
