Author Topic: Pin count difference - DM74S573N  (Read 1923 times)
Offline bitmanTopic starter
  • Open Source Guy jabbing with Electronics
« on: February 18, 2018, 01:37:30 am »
What am I reading wrong here on the chip - I read this as a DM74S573N which I have the data-sheet for here http://pdf1.alldatasheet.com/datasheet-pdf/view/135427/NSC/DM74S573N.html. According to the data-sheet there should be 20 pins - but this chip only has 18?  Color me confused - but I guess I shouldn't be surprised?  I can find it listed on some sites for purchase as an 18pin chip - so I'm pretty sure I have the wrong data sheet, but this model is listed in the sheet and everything seems to match otherwise?
Re: Pin count difference - DM74S573N
« Reply #1 on: February 18, 2018, 01:47:20 am »
Hmmm - I found another datasheet that matches the chp http://www.datasheets360.com/pdf/4783000051525452916. Question from the newbie is, if the model number is the same, how does this happen? What am I missing when I look up the datasheet?
Offline Wimberleytech
« Reply #2 on: February 18, 2018, 02:26:27 am »
I looked in the 1977, 1980, and 1990 National databooks.  18 pins in all cases. I did find a 20-pin datasheet on the web.   :-//
Offline Jwillis
« Reply #3 on: February 18, 2018, 05:25:32 am »
Online 2N3055
  • Country: hr
« Reply #4 on: February 18, 2018, 10:15:55 am »
74x573
18 pin one is old 4096-BIT TTL PROM by NS..
20 pin one is Octal D-type transparent latch; 3-state...
Yeah, there are many instances in industry when they used same numbers for different stuff...
The following users thanked this post: bitman
Offline Jwillis
« Reply #5 on: February 18, 2018, 03:53:08 pm »
Well that's odd, the block diagram in OPs datasheet is showing 16 connections.if you add the Vcc and ground that would make 18 .Its missing Q4,Q5,Q6 and Q7.
Offline glarsson
« Reply #6 on: February 18, 2018, 04:22:22 pm »
Why is it odd that a 1k*4 PROM only has four data outputs (Q0 - Q3)? Why do you expect it to have Q4, Q5, Q6 and Q7?
Offline Jwillis
« Reply #7 on: February 18, 2018, 04:35:05 pm »
Just that the pin outs are showing Q4-Q7 on pins 11,12,13,14
Offline glarsson
« Reply #8 on: February 18, 2018, 06:41:38 pm »
But that pinout is for the 20-pin version that is not a PROM. The data sheet is about the 18-pin PROM, except the pinout on page 2.
Offline Jwillis
« Reply #9 on: February 18, 2018, 06:59:08 pm »
Don't get wrong.It's not my intention to argumentative.I was just wondering why they would present a data sheet like that.It just causes confusion.
Offline stj
« Reply #10 on: February 19, 2018, 08:39:11 am »
you are confusing a 74s573 with a 74ls573.
an easy mistake given that there used to be a schottky version of ttl called 74s, before low power schottky (74ls) was developed.
unfortunatly 74s was also used to designate bipolar rom by a couple of manufacturers.
not all, some used different prefixes to avoid this confusion.
Online newbrain
« Reply #11 on: February 19, 2018, 03:59:44 pm »
Actually, if look at the DS in the OP first post (but not in any other I could find online), you'll see that on page two a 20-pin pinout is shown.
That pinout, though, seems to be for a 512x8 bits memory (still 4096bits), such as maybe a DM54S472, so it has only 9 address lines but 8 data lines.
Probably an early, wrong, version of the datasheet.
Offline Jwillis
« Reply #12 on: February 20, 2018, 11:25:59 am »
Maybe my first reply was confusing but here is the datasheet.
Online newbrain
« Reply #13 on: February 20, 2018, 12:46:44 pm »
An here is the "funny" one with 20pins...which is of course wrong!
