Author Topic: PIN Diode Questions  (Read 2958 times)
Offline rheb1026Topic starter
PIN Diode Questions
« on: March 06, 2018, 05:09:21 pm »
Not sure if this belongs in the beginner or ham radio/rf area...
Is there a way to roughly estimate/calculate the parallel resistance when the PIN diode is reverse biased? I'm looking at the NXP BAP64-02, and the value isn't given in the datasheet.
Another question: when using a PIN diode in the receive path of a moderate (10W) power amplifier, is there a standard way to reverse bias this diode to keep the reverse voltage higher than the RF voltage? Is a boost converter the only way?
Online rfeecs
Re: PIN Diode Questions
« Reply #1 on: March 06, 2018, 05:46:42 pm »
It's going to be negligible.  Reverse biased it will just look like a capacitor.  You can roughly estimate from the datasheet reverse current is a maximum of 1uA at 20V, so more than 20 MOhm.
Not sure what you're asking.  Receive path?? 10W at 50 ohms is about 32V peak, so you need to reverse bias more than that.
« Reply #2 on: March 06, 2018, 06:00:45 pm »
Sorry, should clarify: I plan to use PIN diodes for a transmit/receive switch at the antenna end. The power amplifier will put out 8-10W.
I've attached a schematic of my intended circuit to help understand better. Note that the PIN diode bias voltage is not sufficient, I just copied and pasted from an identical circuit in a low signal level path
I was wondering if there is any way around using a boost converter of some sort to generate the bias for these diodes? The only other option I can think of is to use a relay instead to do the switching. The voltages available will be +12-14V and +5V.
My concern is with the noise generated by a boost converter and keeping it out of the receive path.
Online rfeecs
« Reply #3 on: March 06, 2018, 06:56:59 pm »
I don't know an easy way around it.  If you could switch off the output of the amplifier and possibly switch off the boost converter while you receive?
There are MMIC TR switches out there that can handle 10W and only require a 5V or even 3V power supply.  A quick Google search yields Mini-Circuits VSW2-33-10W as one possibility:
https://www.minicircuits.com/WebStore/dashboard.html?model=VSW2-33-10W%2B
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: March 06, 2018, 07:27:52 pm »
You can possibly use the RF to self-rectify... but you need to accept that this will introduce distortion.
Seven Transistor Labs, LLC
« Reply #5 on: March 06, 2018, 10:31:26 pm »
Thanks, I put in a sample order for a few of those. I'll have to look and see about boost converters with a shutdown pin
I should probably just start a project thread since I'm sure I'll have more questions
Online langwadt
« Reply #6 on: March 06, 2018, 11:23:13 pm »
variable or fixed frequency?
« Reply #7 on: March 06, 2018, 11:26:56 pm »
Mostly fixed... It should operate from 144-146 MHz, so fairly small bandwidth
Offline rfengg
« Reply #8 on: March 06, 2018, 11:29:46 pm »
"Another question: when using a PIN diode in the receive path of a moderate (10W) power amplifier, is there a standard way to reverse bias this diode to keep the reverse voltage higher than the RF voltage? Is a boost converter the only way?"
You do not strictly need a higher reverse voltage from a DC supply to bias it higher than the peak RF voltage due to the self bias developed across the PIN diode.........go thru this seminal paper by Prof Caverly.......it guides you on how to go about this.
Let me know if you need help with the calculations.
https://cdn.macom.com/applicationnotes/AN3022.pdf
Offline G0HZU
« Reply #9 on: March 07, 2018, 02:08:03 am »
Forget all the above and revisit your circuit design and all of these problems will go away if you just make a simple narrowband (classic) diode TR switch. If you place a (lumped) quarter wave section between the Tx diode and the Rx diode the Rx diode can be a shunt ON diode to act as a simple crowbar in Tx mode. The Tx signal sees a 90degrees phase shift through the quarter wave section before it reaches the Rx crowbar diode, then a 180degree phase shift occurs in the reflection from the shorting crowbar followed by another 90degrees on the way back (=360 degrees total) so the receive path looks like an open circuit to the Tx path in Tx mode. So you get high isolation from Tx to Rx in Tx mode. In Rx mode just reverse bias the Tx diode and the Rx diode and the antenna signal will then be routed to the receiver input stage. Both diodes need to be ON in Tx mode and both need to be OFF in Rx mode.
This narrowband TR switch topology has been around for decades, it gets used in CB radios and ham radios and it means you don't need to have a high reverse bias for the Rx diode. Some CB radios just use a pair of limiter/clamp diodes for the Rx crowbar and that saves having any bias in the receive diode(s) but that is to save cost and circuit complexity.
See below for a barebones version of this type of switch. This is a simplified version to help show the basic building blocks and it only has a simple common bias control. It's up to you how you want to add complexity to improve the biasing as you might want to have extra reverse bias voltage  in the diodes in Rx mode. You don't have to use a transmission line for the quarter wave section, you could just use a lumped LPF equivalent made from an LC Pi section(s).
« Last Edit: March 07, 2018, 02:29:11 am by G0HZU »
Online langwadt
« Reply #10 on: March 07, 2018, 03:04:10 am »
might be able to used something really simple like this often used for NMR
https://my.vanderbilt.edu/mrengineering2014/files/2014/03/031914_blog-4-fig-3.jpg
Offline rfengg
« Reply #11 on: March 07, 2018, 03:38:16 am »
A word of caution on advice regarding unbiased limiter diodes.......there is a finite delay before the incident RF turns the limiters ON and during this delay the spike leakage can very well destroy sensitive front ends / preamps.
The advantage of using biased PIN diodes is that you can allways switch in the dc bias before the Tx RF is applied.
« Reply #12 on: March 07, 2018, 02:52:43 pm »
Thanks very much for all the replies! I had forgotten about the 1/4 wave TL, I think that's definitely the way to go for this.
I'm going to start a project thread when I get the time to write everything out, but this will be used in a transverter in the end
Thanks, I hadn't seen this app note before. I gave it a quick read through, but will have to sit down and take more time to go over it. I appreciate the offer
Offline w2aew
    • My YouTube Channel
« Reply #13 on: March 07, 2018, 09:15:44 pm »
I did a video on the lumped quarter wave T/R switch, if you're interested:
FAE for Tektronix
The following users thanked this post: LA7SJA
« Reply #14 on: March 07, 2018, 09:35:04 pm »
Thanks, Alan! I'll have to watch tonight
Love your videos, by the way. Keep up the good work
Offline rfengg
« Reply #15 on: March 07, 2018, 10:58:20 pm »
You ARE the best Alan.......all your videos are concise and very well explained.
The contribution you have made thru your videos is beyond measure......keep them coming  :-+
The following users thanked this post: w2aew
Offline LA7SJA
  • Country: no
  • Acting user manual reader & forum search engine
« Reply #16 on: March 08, 2018, 08:22:11 am »
Steve Jobs " There’s An App For That™"
w2aew "I did a video on that™"
I love your videos! Keep up the good work (please).
Johan-Fredrik
"If at first you don't succeed, skydiving is probably not for you"
