You can do the same thing in MPLAB 8.3 as well. After setting the bits in the UI, go to file & choose export. The settings & the code will be put in a hex file of your choice. In my opinion MPLAB 8.3 is still more reliable & easy to use than MPLAB X. Have tried both.
