Author Topic: LED current  (Read 3534 times)
loga
  • Guest
LED current
« on: October 02, 2013, 04:10:03 am »
I have a circuit shown below but I don't know how to calculate the LED current(I3). The Vs is 5V.
Any ideas?
Edit : I can solve this problem.
« Last Edit: October 08, 2013, 08:20:07 am by loga »
Offline Bloch
Re: LED current
« Reply #1 on: October 02, 2013, 04:45:00 am »
[size=78%]I have a circuit shown below but I don't know how to calculate the LED current(I3). The Vs is 5V.[/size]
Any ideas?
I love to make you home work  ::)
Show how you think it can be calculated.
Offline IanB
Re: LED current
« Reply #2 on: October 02, 2013, 04:54:37 am »
Yes, that doesn't look like a practically useful circuit, it looks more like an exercise.
What have you tried so far, and where did you get stuck?
loga
  • Guest
Re: LED current
« Reply #3 on: October 02, 2013, 07:21:45 am »
It's not my home work. It's a circuit that I see on the internet years ago and looks like a simple circuit but I can't figure out why no need a resistor on the LED branch. I just want to know how LED affect to current I1.
If there is no LED I can solve my problem with KVL.
Vs = I1*R1 + Vf + I1*R2 + I1*R3
Vs = I1*(R1+R2+R3) + Vf
or
I1 = (Vs - Vf)/(R1+R2+R3)
But when the LED is present in the circuit and I1 <> I2 but I1 = I2+I3.
To IanB: this circuit come from $0.99 product from china.
« Last Edit: October 02, 2013, 07:33:51 am by loga »
Online Psi
Re: LED current
« Reply #4 on: October 02, 2013, 07:37:01 am »
R1 and R3 limit the total current in the circuit.
The current through R2 further splits this current.
So the LED is limited by the remainder.
« Last Edit: October 02, 2013, 07:41:57 am by Psi »
Offline ve7xen
    • VE7XEN Blog
Re: LED current
« Reply #5 on: October 02, 2013, 07:42:25 am »
Assume that Vf of both diodes is fixed, but they are not equal. D1 as a 1N4001 will have a lower Vf than the LED, so the LED Vf sets the drop across R2+D1. These assumptions should be enough to make KVL solvable.
73 de VE7XEN
He/Him
Offline AndyC_772
Re: LED current
« Reply #6 on: October 02, 2013, 08:03:07 am »
Combine R1 and R3 into a single resistor, located in the existing position for R1.
Assume a constant forward voltage Vf[led] for the LED, and a different constant voltage Vf[d] for the diode.
Call the battery -ve terminal GND. Now you know the voltages (with respect to GND) on both sides of both diodes.
I2 = (Vf[led] - Vf[d]) / R2
I1 = (Vs - Vf[led])  / (R1 + R3)
I3 = I1 - I2
... and solve from there.
loga
  • Guest
Re: LED current
« Reply #7 on: October 02, 2013, 10:25:38 am »
I3 = I1 - I2
At first I think as your solution. I must assume a constant forward voltage Vf[led] for the LED and I can find I3.
But assume that we don't know Vf[led] but we know Vf[d] say 0.7V.
I simulated this circuit on LT Spice, I tested on breadboard but I can't  find I3. with myself.
That is why I asked how to calculate I3.
Offline AndyC_772
Re: LED current
« Reply #8 on: October 02, 2013, 10:33:54 am »
You need to know Vf[led], it affects I3! You can't calculate one without knowing the other, or at least, the relationship between the two.
