Hello guys
from the bottom of my inexperience I can quite well solder tht components.
I would like to improve the soldering of the smd components, but I have doubts about how to proceed with my equipment
My work is not about new blank boards where to solder smd or IC, but only to replace smd or IC from faulty boards.
My equipment is:
- soldering station with 1.6mm flat tip and 0.8mm fine tip
- hot air station
- wich solder
-new purchase:
flux chipquik smd291I started doing some timid tests, but I have 3 doubts:
a) to unsolder smd or IC I use the hot air station, it is quite easy it seems to me; I have seen that in many videos they first put the flux on
the pins and then heat up to unsolder: is it necessary to use the flux to unsolder?
b) two pin smd soldering: I clean the pads with wich solder and then i clean with isopropyl alcohol, apply the flux on the two pads, put the
smd on, I put a drop of tin on the tip and go to solder the first pin (I hold the component still with the tweezers); then with a firm wire the
second pin. Could it go as a procedure? I seem to perform the steps recommended in the flux instructions:
If soldering with wire solder:
.Prior to soldering the SMD to board, pads need to be clean and level.
.Apply flux on all Pads.
.Place the SMD on pads, Use good lighting and magnification to ensure leads are centered on Pads
.Carefully hold SMD in Place bY pressing down with pick or tweezers.
.With a tinned iron, tack down 3 or more pins.
.with a flat chisel tip iron (temp.controlled) apply solder as required and drag solder across all Pins
.If a solder bridge is formed, use flux and solder braid to remove bridge.
.Clean solder joints with isopropyl alcohol.
.Inspect all solder joints for defects.c) multi-pin smd soldering (IC): I'm confused here.
I did not understand if it is better to clean all the pitches as described above, then apply the flux, and putting a drop of tin on the tip then
drag on all the pins.
I have the doubt because the package together with the flux smd291 says:
If reworking a surface mount board:
.Apply CHIPQUiK flux and use soldering iron to reheat joints
.Extra flux helps ensure solder will flow where needed and avoid short circuits
.If desired, remove excess flux using isopropyl alcohol and lint free wipes or cotton swabs.Since in the flux instructions, as I have reported above, they describe the procedure if you weld with wire, does this second procedure take place without using the wire? In practice they suggest to unsolder an IC for example, DO NOT CLEAN all pad, apply the flux and by heating the new IC will be welded (using the old tin still present?)
Any advice to solve my doubts?
thanks
