Your math looks good. Cool to see the input resistors drop out leaving bias currents depending on R2 only. Input offset voltage is multiplied only by noise gain, basically by definition; and note that goes for DC offset as well as input noise e_n -- same thing.
I would only suggest, in the last steps, splitting the bias current into a common and differential mode, Ib+ = Ibc + Ibd, Ib- = Ibc - Ibd, and working that out. Ibc should cancel out then, and you can be sure only the difference matters. (Actually, as drawn, since the currents are in and out of the amp, it should be the other way around. Alternately, it's enough to prove this separately, and continue with Ibd --> Ib+ = Ib- as shown.)
And likewise, the noise currents of Ibd and Ibc may vary; in conventional bipolar amps, Ibc is dominant (base bias current), while in compensated amps (like LT1115) the majority of base current is supplied internally and Ibc is smaller than, or comparable to, Ibd. In FET amps, they are comparable.
Also, I guess I should write Ib and Ios instead of Ibc and Ibd.
