Author Topic: Please confirm that TTL does not have a special connector  (Read 1090 times)
Offline t1dTopic starter
« on: August 10, 2019, 12:31:52 am »
The best that I can tell, TTL does not have a special connector, like USB, or RS232. Looks like there are common colors for the signal wires, but that there is not a particular connector... It appears that DuPont connectors and pin headers are commonly used. Do I have this correctly? Thank you for your help.
Online ataradov
    • Personal site
Re: Please confirm that TTL does not have a special connector
« Reply #1 on: August 10, 2019, 12:35:59 am »
TTL is a technology, it has no relationship to connectors.
Alex
Offline Nusa
« Reply #2 on: August 10, 2019, 12:45:16 am »
TTL = transistor transistor logic. Used by itself, it most likely refers to the IC chips from the TTL family.
However, that is clearly not what you're talking about. My guess is you're talking about TTL-level serial connections. And the answer to that is: No, there is no hard standard since it's not generally used as an external interface. You can't even count on the order of the pins to be consistent.
Now if you're talking about a specific PURPOSE of the connector, there may be some standard pinouts that are usually followed, but you'll have to get specific in your question if you want those answers.
Re: Please confirm that TTL does not have a special connector -Solved-
« Reply #3 on: August 10, 2019, 01:08:34 am »
Yes, TTL-level serial connections. Thank you for confirming my thinking. I am marking this as "Solved."
Online ataradov
    • Personal site
« Reply #4 on: August 10, 2019, 01:11:03 am »
FTDI pinout seems to be the most popular - https://www.usbgear.com/images/GM-TTL3VT_pinout.jpg
Alex
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: August 10, 2019, 06:19:00 am »
To be pedantic, one might think you're referring to the old parallel port (IEEE 1284), which is TTL leveled, and does not have a special connector (it's just a generic DB-25; or maybe that's too special, I don't know). :)
But yeah if you just mean TTL level asynchronous serial, it's at least three pins, that shows up wherever the hell the designers had free space.  Could be pads or vias on a PCB, could be a header, could be a connector proper.  It's not much to sort out so I wouldn't worry about trying to conform to anything specific.
Seven Transistor Labs, LLC
