Hello everyone
Finally, after months of research, I'm about to assemble yet another prototype of a linear bench PSU. Could you please have a short look at it? May be there are some obvious mistakes?
Basically, it's a regulator from LT3080's datasheet + blackdog's preregulator:
https://www.eevblog.com/forum/projects/very-low-noise-preregulator-for-benchtop-power-supply/msg626382/#msg626382 . Input: ~12V, output: 0-12V, 1.1A.
To be assembled on a protoboard with a ground plane (twin industries 8100-45). I attached how it supposed to look like if done right
. Some components share holes, this is intended
. Topmost TO-220 are misaligned on the picture, this is a rendering issue. Also, diptrace does not support vertical mount of resistors and diodes I replaced them with generic stubs with proper lead spacing.
