Author Topic: Please help identifying the round connector  (Read 1020 times)
Offline doru.cazanTopic starter
« on: April 01, 2023, 08:12:17 am »
Could anyone let me know what connector is the round one? I need to connect my device directly to a scale without the need for a pair of standard 9 pin serial connector. Many thanks!
https://www.coleparmer.co.uk/i/adam-equipment-rs-232-cable-for-scale-indicator/1171033
Offline tooki
Re: Please help identifying the round connector
« Reply #1 on: April 01, 2023, 12:59:46 pm »
Please list the scale’s manufacturer and model number, and measure the connector as accurately as possible.
« Last Edit: April 01, 2023, 01:02:46 pm by tooki »
The following users thanked this post: doru.cazan
Offline jonpaul
« Reply #2 on: April 01, 2023, 01:14:30 pm »
German DIN/Tuchel or Hirose
j
Jean-Paul  the Internet Dinosaur
« Reply #3 on: April 01, 2023, 02:01:40 pm »
Thank you @tooki, @jonpaul!
The serial cable connects using the round connector to a serial port on the Adam AE 403 indicator: https://www.adamequipment.co.uk/ae-403
The serial port is on the bottom (from page 7 in the user manual: https://www.adamequipment.co.uk/media/docs/Print%20Publications/Manuals/AE403_UM_EN.pdf:
Seeing the metal shield around the female connector I am thinking that it is a "very special" connector  |O
Will not have access to the scale/indicator for about 2 week so unfortunately I cannot provide dimension. I am sorry for this; I learned this lesson and will know next time.
Not sure if it helps, on the indicator details page above there is also a service manual: https://www.adamequipment.co.uk/media/docs/Print%20Publications/Manuals/AE403_SM_EN.pdf
I read both manuals but the connector codes are internally assigned, could not find anything based on those.
« Last Edit: April 01, 2023, 02:06:43 pm by doru.cazan »
Offline BeBuLamar
« Reply #4 on: April 01, 2023, 02:50:35 pm »
I am not 100% sure but  I think it's the 4 pin Eurofast M12 femaie connector.
Offline voltsandjolts
« Reply #5 on: April 01, 2023, 04:14:12 pm »
Nah, its not M12.
Note the metal surround with the alignment notch and female sockets. Also, the straight knurling on the lock nut.
I think the same connector type is used for the 7-pin strain gauge connection, seen here.
https://youtu.be/286rBnw3-Bw?t=47
Couldn't see a matching Amphenol or Hirose, which were my first guess.
« Last Edit: April 01, 2023, 04:22:24 pm by voltsandjolts »
« Reply #6 on: April 01, 2023, 04:28:54 pm »
@voltsandjolts  you are perfectly right, it is the same connector: load cell connector has 7 contacts, serial port connector has 4 contacts.
Offline Jwillis
« Reply #7 on: April 01, 2023, 04:54:20 pm »
You sure they're not GX Aviation connectors ? DIN connectors are not quite the same.
« Reply #8 on: April 01, 2023, 04:58:30 pm »
@Jwillis, I am not sure. I looked for GX Aviation connectors on Google Images Search and could not find yet such a connector that has a metallic shield.
Offline Jwillis
« Reply #9 on: April 01, 2023, 05:28:13 pm »
https://www.amazon.co.uk/Thread-Female-Aviation-Connector-Ltsstoreuk-Silver/dp/B07BFDFJ1T/ref=sr_1_1_sspa?crid=2IL0TJQC4HF6Q&keywords=GX%2Baviation&qid=1680369979&sprefix=gx%2Baviation%2Caps%2C226&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
Other question is size . GX12, GX16 or GX20
Oh wait I see what you mean about shielding . But I wonder if that is necessary .
« Last Edit: April 01, 2023, 05:30:27 pm by Jwillis »
« Reply #10 on: April 01, 2023, 05:32:00 pm »
Thank you @Jwillis! I noticed that the connectors on Amazon do not have this metallic shield (please see the attachment to this post).
Edit: I am not sure if the shield is necessary. Regarding the size, I will get a caliper with me next time will be on the site.
« Last Edit: April 01, 2023, 05:34:42 pm by doru.cazan »
Offline Jwillis
« Reply #11 on: April 01, 2023, 06:24:59 pm »
What about these. They,re not a GX aviation but a XS aviation. https://www.amazon.ca/Aviation-Push-Pull-Circular-Socket-Connector/dp/B07QF3MSWW
Maybe that will narrow things down a bit more.
« Reply #12 on: April 01, 2023, 06:31:57 pm »
@Jwillis, these XS connectors look very similar, have to find one with thread instead or screw / thread. Thank you
