I'd suggest use an LDO on opamp rails to lower total supply voltage*.
I totally fail to see why you specify an
LDO, specifically, when you have significant voltage headroom and want to bring it down. A normal linear regulator works.
LDOs, especially older generation (looking at you, 1117) tend to be compromised compared to traditional normal-drop out linear regulators, for example having peculiar output capacitance requirements that need to be carefully followed to avoid oscillation.
Availability of high-voltage LDOs is on a poor side as well because it's quite a niche use case to require LDO when you have a lot of voltage available. In any case, finally whether a manufacturer thinks the dropout is low enough to be called an LDO is quite arbitrary so setting yourself such meaningless limitation is not fruitful.
