Electronics => Beginners => Topic started by: roogadget on September 28, 2018, 12:25:46 pm
Title: PMIC question
Post by: roogadget on September 28, 2018, 12:25:46 pm
I am designing the power management section for my project and I'd like some feedback on my design choices.
I am wondering about a PMIC chip (Boost/Buck Converter) that I've picked.
http://www.ti.com/product/TPS55165-Q1 (http://www.ti.com/product/TPS55165-Q1)
There is a pin that requires an external 5V input when a 12V output in desired. (Power Good Pin - PG)
(http://)
My input varies between 9V and 18V. So I would need to step it down to achieve the 5V required.
I also need a 5V output because my STM32 requires 3.6V (Which I'll likely use a linear voltage regulator to achieve).
I would like to know if this is the appropriate method to handle various inputs and stepping down voltages.  :-//
Title: Re: PMIC question
Post by: stmdude on September 28, 2018, 01:01:53 pm
From the datasheet:
The power-good (PG) pin is a low-side FET open-drain output which is released as soon as the output voltage is
greater than the PG undervoltage threshold ....
It's an output, but you can't really put any load on it.
Which means, you'll need to convert your 12V output into 3.3V for the STM32.  Plenty of DC/DC bucks does this for very little money.
Post by: roogadget on September 28, 2018, 01:34:10 pm
Wow! Thanks! I just avoided a big problem.   :-+
Post by: T3sl4co1l on September 28, 2018, 08:58:26 pm
So you need what voltages?  Just 5V, with an LDO to make 3.6V?  (3.3V is more traditional, do you have a reason for going on the high side of that?)
That reg has a 5V output option, but it looks like a much cheaper buck regulator will meet your requirements in that case.
Tim
