Author Topic: PNP equivalent of ULN2803?  (Read 11104 times)
Offline dog80Topic starter
« on: October 30, 2013, 09:28:04 am »
I'm trying to drive a common anode 7-seg display with an Arduino and use a ULN2803 to drive the cathodes.
Is there a PNP equivalent to the ULN2803 to drive the anodes instead of using individual transistors?
Offline David_AVD
Re: PNP equivalent of ULN2803?
« Reply #1 on: October 30, 2013, 09:39:43 am »
What you need to search for is "octal high side driver".
They are not as common or cheap as the low side (NPN) ones though.
Offline Psi
« Reply #2 on: October 30, 2013, 09:40:59 am »
also, if you can handle SMT chips it will be much easier to find one.
DIP pnp transistors arrays are much less common than SMT
Offline mariush
« Reply #3 on: October 30, 2013, 09:43:32 am »
UDN2981 may be a suitable part.
See this thread where several ICs were suggested : https://www.eevblog.com/forum/projects/micro-controller-controlled-led-matrix-design-question/
ps. In another thread, MAX7219/MAX7221 were mentioned by someone. But they're more complex: http://datasheets.maximintegrated.com/en/ds/MAX7219-MAX7221.pdf
« Last Edit: October 30, 2013, 09:49:33 am by mariush »
Offline ivan747
« Reply #4 on: October 30, 2013, 05:11:56 pm »
Another solution is getting a common cathode display instead.
