Note: I just found a supplier that can make custom transformers in low quantity. I'm excited! I think this will work!
Now, I'm still confused about something: note 6 on page A-9 says the voltage between TP2 and TP4 is 25V +/-10% in low current range. Will this be different in high current mode?
The note is basically telling you the max. winding voltage of the secondary but, come to think about it, I assumed that the center-tapped point is at half that; 12VAC. I may be wrong. Why don't you measure the resistance of each half of the seconary to confirm that it is, in fact, at the half-way point. It could be a 14VAC/10VAC or other odd split.
In high-current mode, S2A switch only takes current from half (?) the secondary so that means it must sustain the full rated output of the power supply of 3A. So, I misspoke about using the 50VA (1182L12) transformer as its rating requires both secondaries to be in parallel to sustain 4A (however, 1182M12 can sustain 3.3A on just one half).
Plus, it does look a lot like a center tapped transformer, am I being dumb assuming this is a 50V center tapped? But the drawing the center tap is bit out of center. Is it possible they are different voltages or am I just being paranoid? Or they are completely different windings?
EDIT
Sorry for the tons of silly basic questions. I'm learning and transformers are not something I've dig in deeper yet. Also, thanks to everyone, I'm learning a lot here. <3
It may look a bit off but I wouldn't trust the visual. If each half is different it should say so somewhere.
In the absence of that, I'd confirm by actually checking both winding resistances.
It's NOT a 50VAC CT (or 25VAC-0-25VAC) for sure!
The reason that it's using half the secondary to produce a max. 8V output is so that it only has to burn 4VAC vs. 12VAC+4VAC to get 8VDC out (@3A; 12W vs 48W in the output transistors).
FYI: I measure 51VDC between TP2 and TP4 on my E3611A which makes sense since my supply can go to 40VDC output. And is consistent with note 6: "E3611A 47V +/- 10%"
