Author Topic: Problem with using 2 step-up with MT3608  (Read 1657 times)
Offline moslemi_mr@yahoo.comTopic starter
  • Country: ir
« on: October 09, 2021, 06:28:43 am »
Hi to all,
I want to use two MT3608 in one board for producing 2 different voltages (5V , 25 V) from 3.7 V input (Battery).
When I run each of these two circuits separately, everything looks good (circuit No. 1 produces 5V and circuit No. 2 produces 25 V).
But, surprisingly, when both of circuits turn on, circuit No. 1 can not regulate and its out put goes to 10 V. Of course, this voltage is not constant and varies with varying input voltage or load current.
Have you ever faced this problem?
Can you help me fix this error?
For more information, I attached the schematic.
Offline mariush
Re: Problem with using 2 step-up with MT3608
« Reply #1 on: October 09, 2021, 07:45:11 am »
I suspect too high current pulses from the input, and the battery internal resistance causing issues.
I see some problems with the circuits ...
22 uH for inductors seem like very high value, and should also be adjusted according to the circuit needs.  The 5v output doesn't need same inductor value as the  one aiming for 25v, should optimize according to needs.
The datasheet for MT3608 says "The  recommended  values  of  inductor  are 4.7  to  22μH. Small size and better efficiency are the major concerns for portable device, such as MT3608 used for mobile phone. The inductor should have low core loss at 1.2MHz and low DCR for better efficiency. To avoid  inductor  saturation  current  rating  should  be  considered"
I'd probably test the circuit with a more reasonable inductor, like 6.8uH .. 10uH. 22uH seems a bit much, but then again you also don't say how much power/current on 5v , how much power/current on 25v
1n4148 is not particularly great, there's better options but it will work.
I don't see any input capacitance, the regulator needs it even when running from battery... I'd suggest  2 x ~ 10uF 25-50v rated ceramics in parallel, x5r , x7r at the input of each regulator  ... 22uF ceramics may be more expensive.
On the output, for the 5v output 22uF ceramic would be fine, as long as voltage rating is up, 25v+ ... for the 25v out regulator, you'll want at least a 35v rated ceramic but it will practically be  1-2 uF in capacitance almost pointless at that output voltage.   I'd suggest going with something like a 10uF 50v or higher rated ceramic in parallel with a 10-47uF 35v polymer capacitor.
You should look at the datasheets of other similar regulators... for example other 1.2 Mhz-ish step-up regulators. The datasheets for those may be more detailed and give you more info about what inductors are optimal , how to calculate things... of course due to slightly different internals of the chips, some of the info may not be
For example, I just googled for "1.2 mhz step-up regulator" and found LT1961 and MIC2619 and LT3426 ..
LT3426 : https://www.analog.com/media/en/technical-documentation/data-sheets/3426fb.pdf
MIC2619 : http://ww1.microchip.com/downloads/en/DeviceDoc/mic2619.pdf
LT1961 : https://docs.rs-online.com/67d8/0900766b81412881.pdf  (see the inductor choice section in datasheet)
  • Country: ir
« Reply #2 on: October 09, 2021, 10:50:37 am »
Thanks a lot for your attention.
There isn't any load at the outputs.
I decreased the value of the feedback resistances (2.2K AND 15k) instead of (110K and 15K) and the problem fixed for now!!!
It is not reasonable bot it works. There isn't any condition related to feedback resistances in datasheet.
Offline Terry Bites
« Reply #3 on: October 09, 2021, 12:30:23 pm »
They are suffering from a lack of input decoupling that makes the converters interact. Check your wiring for ground and supply loops. Here's how it should be wired.
Offline Terry Bites
« Reply #4 on: October 10, 2021, 04:38:16 pm »
Its not unusual for switchers (and linear regulators) to not regulate without a minimum load. Lowering the FB resistors has added some current load. Voila!
An LED and series resistor would do the same thing with power on indication benefits.
