Author Topic: Point me in the right direction of a terminal!  (Read 674 times)
Offline rhubarb
  • Country: wales
« on: June 16, 2021, 08:10:42 pm »
Hello EEV Blog!!
I'm brand new here and this is my first post so please correct me if this isn't quite the right place for this kind of question.
I'm forever using these screw terminals in my little projects
[attachimg=1]
But someone recently showed me those lever-action Wago 221 connectors. At first I was excited because they looked even easier to use and quite aesthetically pleasing but I soon realised they don't serve the same function, so here's what I'm after:
Can anyone point me in the direction of some lever connectors like the Wago 221 with separate solder terminals for each wire hole? Rather than one where all wires inserted are shorted to each other? Does such a thing even exist?
Sorry if this is a dull question but I really don't know and I've tried looking everywhere! Thanks in advance!
Rhubarb
Offline rhubarb
  • Country: wales
Re: Point me in the right direction of a terminal!
« Reply #1 on: June 16, 2021, 08:12:06 pm »
As a side-note: It's the 3-part srew connectors i usually use so one of those preferably!
Online langwadt
Offline calzap
« Reply #3 on: June 16, 2021, 09:12:24 pm »
Wago makes mounting carriers that hold multiple 221 terminals.
Mike in California
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: June 16, 2021, 09:17:11 pm »
phoenix contact has many
Offline Buriedcode
« Reply #5 on: June 16, 2021, 09:21:00 pm »
Offline JustMeHere
« Reply #7 on: June 17, 2021, 04:37:09 am »
Offline rhubarb
  • Country: wales
« Reply #8 on: June 18, 2021, 06:49:50 pm »
Thanks for all the suggestions everyone!
I'll weigh them all up and make a decision.
Cheers again!
Online Renate
« Reply #9 on: June 19, 2021, 12:16:44 pm »
I personally like these.  A bit expensive,  but they work well.
https://www.mouser.com/Connectors/Terminal-Blocks/Pluggable-Terminal-Blocks/_/N-7rqe3?P=1z0z2v9Z1yvsm2e
Oh, I HATE those.
A pluggable terminal block just seems to extend the problems to another dimension.
If they sold solderable/crimpable cable plugs as an option it would be tolerable.
You get some piece of equipment with the Phoenix sockets on it and you end up with something that has wonkiness at both the sockets and the terminals.
Also, there is no possibility of cable restraint.
If the only possibility for Phoenix sockets is to put a Phoenix plug/terminal adapter in, why bother?
Online langwadt
« Reply #10 on: June 21, 2021, 10:22:34 am »
Oh, I HATE those.
so you can replace a board without f-ing up all the wiring
Offline Terry Bites
« Reply #11 on: June 21, 2021, 03:08:01 pm »
I have always steered clear of wago, they feel just a bit too flimsy. For playing on the bench, 'multicomp' make loads of flavours. They are inexpensive but ok. https://cpc.farnell.com/search?st=pcb%20terminal%20multicomp also see https://cpc.farnell.com/search?st=pcb%20terminal%20camdenboss cheap and cheerful.
Pluggable are great if you need to quickly swap out a module or board with loads of connections and zero errors. Otherwise they are just another thing to fail and waste your time.
Serious terminators like ferrules on thier wires. I like 'em, but then I'm related to the Earl of Pedantry.
« Last Edit: June 21, 2021, 03:16:36 pm by Terry Bites »
Offline jmelson
« Reply #12 on: June 21, 2021, 03:17:28 pm »
I use On Shore technology (yeah, on shore if you are in China) clones of the Phoenix Contact 2-part screw terminal plugs.
Just for reference, look up Digi-Key part numbers ED2822 and ED2457.  I buy these from a local representative for about half the Digi-Key price, but I need to order them 8-10 weeks in advance.  When I allow myself to get caught short, I get them from D-K.
Jon
