Yes, 180 degress is normal. I've never seen one that is not.
No, do not mess with the trimmer screws.
Does it have a transparent housing and can you see the insulation sheets between the moving plates?
Much thanks to you. Yes, 180 makes sense what with two semicircular vanes meshing.
Well it's clear in places. I've just had a really close up look and i think i've found the problem. A great splurge of fawn coloured glue has been laid over many components adjacent to the varicon, and down two of its sides. Incredibly, upon close inspection i can see dozens of fragments of this glue inside the varicon! This is even more interesting to me as i watched a YouTube video demonstrating this boombox once, and it had exactly the same issue with the dial! It even pegged out at the same spot. So it's a factory cock up.
Tempting to try a little force and see if i can grind up the fragments maybe, or bite the bullet and go for a difficult extraction and perhaps open the varicon for repair.
Note: i meant to call it wax as that's what it is. Maybe i can melt it away...
