Author Topic: poor man ovenized buried-zener reference  (Read 4713 times)
Offline 1001Topic starter
« on: September 14, 2016, 08:16:00 pm »
hi everybody! Could be a good idea to ovenize a cerdip MAX6350 buried-zener by a to-220 bjt as heater glued with pt100 or pt1000 RTD onto voltage reference? temp drift and hysteresis could going better?
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: poor man ovenized buried-zener reference
« Reply #1 on: September 15, 2016, 01:19:51 pm »
as zener voltage is also a function of current, you also need constant current circuit in there...
Offline helius
« Reply #2 on: September 15, 2016, 01:29:23 pm »
I read "poor man ovenized" and thought it must be a Guardian headline.
Offline dannyf
« Reply #3 on: September 15, 2016, 01:35:58 pm »
Roasted would be tastier.
« Reply #4 on: September 15, 2016, 05:05:00 pm »
This has come up before in this forum more times than I can count on my fingers.  The general idea goes like this:
"If I take (this) inexpensive monolithic reference IC and put into a temperature controlled environment, won't that be as good as a Fluke 732?"
The short ...
Poor man, ovenized or rosted, maybe doesn't buy tantalum-nitride resistor networks, I am thinking to a
5Vdc reference to use with ltc2400 or LTC2410.
LTZ1000 is not for poor man, LM399 needs expansive resistor to
lower at 5V. Maybe I can use LM399 with LTC1043 to divide by 2 but I don't know if temp drift can
raise or not. I can buy MAX6350 in cerdip case, it has a buried zener (like LM399, LT1021, AD586) and
laser wafer trimming of high stability thin-film resistors inside the same ceramic package to lower Vz.
It remains the problem of noise, 1.2µVp-p for LTZ1000 vs 3µVp-p for MAX6350.
I don't well understand you if I can avoid any hysteresis ovenizing cerdip MAX6350...
Temperature hysteresis for LTZ1000 and LM399 are different from Temperature hysteresis of MAX6350?
Of course I know it is impossible to reach LTZ1000 standard by a cheap reference.
Tnx a lot DiligentMinds.
« Reply #5 on: September 16, 2016, 01:00:15 am »
So, can you describe in great detail all of the things you intend to do with this reference?
Don't be cruel to him, we have to treat these proto-voltnuts gently and slowly pull them deeper and deeper. It's a lot like getting someone hooked on hard drugs, your first LM399 is free..  >:D
