Author Topic: psu power ratings  (Read 1054 times)
Offline m3vuvTopic starter
psu power ratings
« on: April 24, 2022, 12:38:53 pm »
hi,just thought i would ask,are linear power supplys built higher than they are rated for current wise,my 10a linear psu has a torroid about 3.5 inches deep and 6 inches dia,this seems large for just a 10 rating.
Offline IanB
Re: psu power ratings
« Reply #1 on: April 24, 2022, 01:04:34 pm »
"Just a 10 amp rating" is a weird thing to say.  10 amps is a huge current for a laboratory PSU.
« Reply #2 on: April 24, 2022, 01:53:19 pm »
i didnt need to kow if its wierd question,how about if you dont know the answer to my question and cant help dont comment!
Offline BrokenYugo
« Reply #3 on: April 24, 2022, 02:04:34 pm »
The most expensive part isn't going to be oversized. VA rating drives the core size, not amps.
Offline Wallace Gasiewicz
« Reply #4 on: April 24, 2022, 02:25:15 pm »
A 1000 volt amp toroid transformer is about this size apparently, look down this link on page four and find one about your size:
https://www.hammfg.com/electronics/transformers/power/1182.pdf
The following users thanked this post: m3vuv
Offline gnif
  • Views and opinions are my own
    • AMD
« Reply #5 on: April 24, 2022, 02:31:02 pm »
Once again, how about you settle down and stop snapping at people, this is a public forum, nobody is obligated to answer your exact question, and everybody is allowed to comment on your question. Why are we still trying to get you to understand this?
« Reply #6 on: April 24, 2022, 02:52:55 pm »
You ask why,maybe because people still dont get it,let me make it clear to everyone who wants to reply,if you cant help with the specific question/questions i ask "DONT COMMENT!!!!" is that clear enough?.
« Reply #7 on: April 24, 2022, 02:59:09 pm »
just had a look at the link wallace,i get the impression for the same v/a ratings a torroid is bigger than an I/E core?
Offline gnif
    • AMD
« Reply #8 on: April 24, 2022, 10:40:41 pm »
This is not your forum, nor is this how forums work. YOU are wrong, not the people commenting here. YOU can ignore these comments if they don't apply, it's that simple. Is THAT not clear enough?
Of the 55,553 members here, YOU are the only person making this complaint... what does that say to you?
If you're not happy with this, find another forum that operates exactly as you demand it to and go there.
« Last Edit: April 24, 2022, 10:44:46 pm by gnif »
The following users thanked this post: TomWinTejas
Offline sahko123
  • Country: ie
« Reply #9 on: April 24, 2022, 11:43:42 pm »
You shouldnt get angry at people trying to get a clarification on your question because they are trying to help answer it.
Yes power supplies might be able to output higher currents than their rating but generally would be limited to that rating to make sure no damage occurs. Transformer size relates to power not current. The bigger a mains transformer is the more power it can supply. So for example if the power supply is rated for 10A at 24V you would get 240W and the transformer might be rated for 300VA to be account for in-efficiency
Asking for a friend
Offline bdunham7
« Reply #10 on: April 25, 2022, 02:34:50 am »
Sir, this is EEVBlog.
Not typically AFAIK.  I have some linear PSU carcasses (Tektronix by GWInstek) that have about 160W total DC output and the EI core transformer is about as big as you say yours is, maybe a bit smaller.  The unit says "300W 386VA" on the back.  So if you have a 320W DC output PSU, you figure in a similar low-ish efficiency and average-to-RMS current ratio and you are looking at maybe ~600W and 800VA maximum input.  So a 1kVA-sized transformer isn't surprising.  EI transformers of that size are 6-7" cubes and weigh 25-35lbs.
Offline mikerj
« Reply #11 on: April 25, 2022, 03:15:09 pm »
You regularly ask for help and then immediately get your knickers in a twist when someone points out an issue.  This is a "you" problem, no-one else's.
Transformers are rated in VA; you have provided the current your linear supply can deliver, but not the voltage.
Offline not1xor1
« Reply #12 on: April 25, 2022, 04:09:38 pm »
The size of the transformer is related to the power (VA).
The size (section) of the wires used in the windings is related to the current.
So your question is nonsensical.
