Author Topic: What is this binding post accessory called?  (Read 1434 times)
Offline HermannsForestTopic starter
« on: February 10, 2022, 04:32:48 pm »
I would like to purchase more of these flat metal bars that connect the binding posts of power supplies. I cannot find what these are called, let alone a place to purchase them.
They apparently come with BK Precision power supplies. Maybe someone with better Google-Fu can help me.
Offline rstofer
Re: What is this binding post accessory called?
« Reply #1 on: February 10, 2022, 04:53:28 pm »
The following users thanked this post: MK14, HermannsForest
Offline Terry Bites
« Reply #2 on: February 10, 2022, 05:59:27 pm »
eg www.mouser.co.uk/ProductDetail/Pomona-Electronics/4115?qs=sGAEpiMZZMvxX9Q80wbhCRhfDiQ2USVb
but there must be more makers surely?
I think because most dual binding posts are aimed at the audio market.
By comparison your bench psu terminals are a special... For currents under 32A crimp your own links.
I made my own lifetime supply out of brass on a CNC mill. Cost nothing, time nothing.
Offline TimFox
« Reply #3 on: February 10, 2022, 06:12:53 pm »
The shorting bars are more commonly used on power supplies than on audio equipment, since they allow a quick attachment from one or the other power post (+ or -) to the center ground post.  The exact cuts in the bar allow the bar to pivot one way or the other (or to neither post) without falling off the ground post, or to allow complete removal (and loss).
Online CaptDon
  • Country: is
« Reply #4 on: February 10, 2022, 11:54:43 pm »
Standard for binding post spacing is 3/4" center to center. Then there are tons of stuff ready made that will plug right in Banana to BNC / Etc.
Offline TomWinTejas
« Reply #5 on: February 11, 2022, 12:11:44 am »
Like others have said, Pomona makes some... here's a different model than others have specified:
https://www.digikey.com/en/products/detail/pomona-electronics/5145/737158
Offline Xandinator
« Reply #6 on: February 11, 2022, 02:45:42 am »
Paperclips (literally :-//)...
You can drill and cut spares from unused CCL.
Offline Terry Bites
« Reply #7 on: February 11, 2022, 02:56:38 pm »
The link is not current generally carrying, it just connects force to sense when remote sense is not in use. Then there are those days when some other fancy arrangment is in use so its not sensible to use paperclips. You don't want your links sparking/ exploding (at eye level) before your current trip saves the day.
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=19mm+banana+plug&_sacat=0&LH_TitleDesc=0&_odkw=19mm+banana&_osacat=0
Offline tooki
« Reply #8 on: February 11, 2022, 06:35:57 pm »
Actually, they’re really, really common in audio, because of speakers which can be bi-amped: they have two pairs of binding posts, bridged by shorting bars by default.
And those of course definitely are current-carrying.
Offline Xandinator
« Reply #9 on: February 12, 2022, 11:50:51 am »
Even worse: Most of the PSUs in student labs (almost exclusively where I've seen the paperclip "method" being used) don't feature tripping devices. I can understand how this sort of quickfix gets to proliferate throughout the busy course schedules, what I don't get is why you would want to mess with test equipment unnecessarily in the first place - probably the same hooligans walking the street and messing with other people's cars. Neither can I see any reasons à la "Wow so now that's what's been missing on my own PSU at home let's fiddle around and apply five finger discount".
