Hi everyone,
I was wondering if there are any safety concerns with the device and any concerns in the environment if the device's +5 V is touching an aluminum casing which will be exposed to the user. Please assume that there is no way for the device ground to somehow touch this +5 V. Also, the internal source resistance of the +5 V source will be large enough so that only max current of ~50 mA can be output when shorted with ground.
My assumption is that nothing will happen since the +5 V and its ground will be well insulated and this 'floating' +5 V will have no way to travel to ground or any parts of the device traces unless the user punctures the device accidentally and shorts something.
Here is a photo to better illustrate the device structure (
https://imgur.com/a/ukCvaS2).
Thanks!
