sorry i didnt notice this thread got bigger.
i dont do a lot of HV things so im not really looking into kVs except from maybe a really bad inductive spike.
anyway today on the way home today i thought about using 3/8 inch copper pipe and a bunch of 1meg 1% resistors. then put layers of heatshrink tubing around...
im thinking about 9meg and 100k(+1meg input imp) voltage divider which at 800V gets around 70mW heat.
for the capacitance though, maybe ill try it out with small hv ceramics or a twist-wire cap
maybe put a MOV or series back-to-back zener across the 100k?
i wonder if keeping the 2/3 inner vs outer diameter to keep the 50ohm impedance still critical?
that last video posted by joeqsmith looks promising, the RG-8 inner insulator does fit nicely inside a 3/8" tube then taper it to fit RG-58 which is still very stiff for probe use
