Author Topic: Possible disadvantages of splitting the GND thermal pad of LTC3633  (Read 249 times)
Offline bmxseshTopic starter
  • Country: ru
Hello, I wanted to ask from electrical standpoint, what are the possible drawbacks of splitting the GND pour at the thermal pad of LTC3633 DC-DC converter to route a signal to the opposite side of the chip?
Thank you,
-bmxsesh
Offline jwet
Re: Possible disadvantages of splitting the GND thermal pad of LTC3633
« Reply #1 on: December 17, 2024, 03:20:50 pm »
I don't think its a great idea and would look for alternatives first.  One thing that you could do is to reduce your trace widths on low current pins- they all seem rather large.  This could give you some layout room to squeeze traces to make that connection.
A via on each side and a trace under the iC would be preferable.  Though usually that thermal pad is via'd to both sides  I don't know what those pins are w/o schematic but do they require a short run?
The IC die is bonded to to that slug on the inside, probably mostly in the center, its a pretty small die.  By having that gap, you have a thermal gradient across with hot and cold spots.
Are you operating the parts at its maxes as far as power goes, etc.
The other issue is that you're really depending on solder mask quality next to tinned area to make it work, not completely planar and probably not a 100% yield kind of deal.
Also, those under IC thermal pads are supposed to be full of Vias to aid thermal conduction to the other side, etc.
The data sheet has some reasonable looking layouts included.
My 2 cents
The following users thanked this post: bmxsesh
  • Country: ru
« Reply #2 on: December 17, 2024, 03:43:15 pm »
I realized that it's just the break in the GND plane (board wise) which is not a good practice
I tried going without internal GND layer and route it on the bottom to make sure every DC-DC converter has its own GND return path
I should probably stick to the datasheet and have an internal power ground
Offline jwet
« Reply #3 on: December 18, 2024, 07:24:45 pm »
You don't have to go 4 layer I wouldn't think unless there are other places that it might help...
