Looking at the datasheet, that is a memory / low current standby capacitor. It has a 4 ohm internal resistance and charge / discharge currents in the mAs range - 18mA discharge is mentioned.
12V is the maximum voltage you can put across it. You treat it like a capacitor, not a battery, ie. it discharges to zero volts.
