Author Topic: Potting an electrolytic capacitor will make it last longer?  (Read 7139 times)
Offline ocsetTopic starter
« on: August 25, 2018, 05:30:43 pm »
Hello,
The following Philips Xitanium LED driver has a big “wet” electrolytic capacitor in it……and several smaller ones…..but they are all totally surrounded in potting compound. Do you believe that this will make them last longer than if they were not buried in potting compound?
Philips Xitanium LED driver (75W)…
http://www.docs.lighting.philips.com/en_gb/oem/download/xitanium/Xi_LP_75W_0.2-0.7A_S1_230V_S240_sXt_929000963206.pdf
Offline Zero999
  • 0999
Re: Potting an electrolytic capacitor will make it last longer?
« Reply #1 on: August 25, 2018, 05:46:33 pm »
I don't see how it will make it last longer, more like the reverse if the potting compound reduces the capacitor's ability to dissipate heat. It's also a potential safety issue. If the capacitor fails, the pressure will build up to a higher level, than it would do if the vent were allowed to pop open and vent the gas.
The following users thanked this post: ocset
« Reply #2 on: August 25, 2018, 06:21:10 pm »
Thanks, but i assume that in a totally enclosed enclosure, the potting compound would always make it easier for heat to get out of the capacitor?
Yes i did think of the need-to-vent too....but philips potted over the can top......probably only about 5mm of potting covering the can top though....so could still explode out.....
presumably no 'lytic explosion would be enough to fracture the 1.5mm thinck plastic enclosure
Offline Zero999
  • 0999
« Reply #3 on: August 25, 2018, 06:27:29 pm »
Potting stops thermal radiation and convection, leaving only conduction, which will be dependant on the compound, so I would expect it would act as a better thermal insulator, than free air.
As far as explosion is concerned, I think it will depend on the hardness of the potting compound, with the softer, more elastic compounds being safer, than the harder more rigid ones.
Offline voltsandjolts
« Reply #4 on: August 25, 2018, 06:59:35 pm »
There are thermally conductive potting compounds such as Dow Corning TC6020 with conductivity of 2.72 W/mK, whereas RTV3120 is around 0.001 W/mK.
Still air is around 0.05 W/mK
So, potting could make thermal issues worse or better. It depends.
The following users thanked this post: thm_w, ocset
Offline Zero999
  • 0999
« Reply #5 on: August 25, 2018, 07:41:32 pm »
Yes there are some relatively high thermal conductivity compounds available, but how do they compare to convection and radiation through air? I know for power components, it's definitely better to use a heat sink, than relying on any potting compound, but I wouldn't know about something like a capacitor, which shouldn't get that hot.
Improved heat transfer between the capacitor and other components might also be a bad thing, if there are other high power components on the board, which will heat the capacitor up more.
Offline mariush
« Reply #6 on: August 25, 2018, 07:59:48 pm »
I think those are potted more for better reliability, to prevent humidity and vibrations, to make them better for outside use... see the notes in datasheet ..
Application
•Road and street lighting
•Area lighting
•Tunnel lighting
•Industrial lighting
They're also designed more or less to be quickly and easily replaced with spare parts so they don't care if you can or can not desolder a capacitor, or that the capacitor blows after 1-2 years of operation... it's probably considered low enough failure percentage and potting them is probably cheaper than conformal coating and water proofing the case and everything else.\
Offline David Hess
  • DavidH
« Reply #7 on: August 25, 2018, 09:36:41 pm »
Radiation is insignificant compared to convection and conduction unless the temperature is much higher than you will want to operate the capacitor so it can be ignored.
« Reply #8 on: August 25, 2018, 09:48:15 pm »
thanks, i thought that the potting compound can help conduct the heat from the components to the inside of the enclosure, where it can then conduct through the enclosure wall, and then convection currents can move the heat away from the  outer surface of the enclosure (even if its a plastic enclosure).....in this way, and in conjunction with a potting compound like the 2.73W/mk mentioned kindly above by voltsandjolts, a potted power supply would be more thermally optimised than a non potted one?
Offline David Hess
  • DavidH
« Reply #9 on: August 25, 2018, 10:31:55 pm »
Yes, using a high thermal conductivity potting compound would be better than air.  Sometimes they use thermal pads between the parts and enclosure or even heat pipes.
Offline Kirkhaan
« Reply #10 on: September 03, 2018, 06:00:40 pm »
Indeed, and when applying the more harder/rigid potting compound, often special rubber caps are placed on top of the ELCAP, leaving some room for the pressure relief valve to open and electrolytic to get out. This way no excess pressure is build up and the ELCAP can die in a controlled (and safe) way...
Offline Wolfram
  • Country: no
« Reply #11 on: September 04, 2018, 03:31:07 pm »
This sounds unrealistically low. The only number I found in this range were in this datasheet: http://media.erapol.com.au/wp-content/uploads/files/products/silicone/condensation/Dow%20Corning%20Silastic%203110.pdf , but given in the units of calories per second centimeter celcius, corresponding to 0.24 W/mK. Other sources place RTV silicone in this ballpark as well (around room temperature): https://www.sciencedirect.com/science/article/abs/pii/S001122759700146X
Offline Kjelt
« Reply #12 on: September 04, 2018, 03:46:28 pm »
They are potted because they are outdoor drivers.
Besides the driver has a thermal protection, an ntc measured by the microcontroller.
Most metal indoor drivers from Philips have a thermal spot printed on the housing, that is where the temp is measured.
Normally potting would distribute the heat over the device.
Offline In Vacuo Veritas
  • I like vacuum tubes. Electrons exist, holes don't.
« Reply #13 on: September 04, 2018, 04:46:52 pm »
Are you really an engineer? Which breakfast cereal did your degree come with?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #14 on: September 04, 2018, 04:56:46 pm »
Potting probably reduces the diffusion of electrolyte, but I wouldn't count on it to help significantly, you're stopping rubber with rubber.
Also, that electrolyte has to go somewhere.  Most of it will remain diffused inside the potting, but some of it may condense in pores and interfaces in and around the potting, which could be an electrolysis/corrosion hazard just the same as any leaky cap is (but more limited, to such locations).
Conductivity: air sucks, particularly when the device is compact and there is little room for airflow within the enclosure.  Typical figure is 0.045 W/mK, but this is going to be a hand-wave because heat diffuses rather than conducts, and some convection always occurs.
It can be much higher where convection (chimney effect) takes place, but this requires more room, or more temperature differential.
Speaking of, temperature differential.  Convection only requires that, and gravity.  Putting some components inside a closed metal box incurs two convection steps, so the peak internal temp rise is almost double (very roughly speaking!), compared to the case for an open or well-ventilated enclosure.
A fan can be desirable inside a sealed enclosure, for this reason.  Better is just to design it so everything sinks heat to the enclosure directly.
These may be of interest,
http://www.cde.com/resources/catalogs/MLP.pdf
but good luck budgeting for it ;)
Seven Transistor Labs, LLC
Offline floobydust
« Reply #15 on: September 04, 2018, 05:12:41 pm »
Old Sangamo electrolytics had a hard epoxy seal.
I see they crack with age or due to some pressure building up within the capacitor.
I've never seen another cap manufacturer do this.
edit: These are from the 1980's when there were no safety vents on electrolytic capacitors.
« Last Edit: September 04, 2018, 05:53:42 pm by floobydust »
Offline David Hess
  • DavidH
« Reply #16 on: September 04, 2018, 05:23:42 pm »
The inverter style backup generator I have has the entire inverter board potted to half way up several large snap-in aluminum electrolytic capacitors but with their tops are exposed, presumably they would rupture safely there.
Offline Gyro
« Reply #17 on: September 04, 2018, 05:59:45 pm »
treez may have his faults but your stupid sarky one-line comments don't help anyone. If you're going to make such comments, then FFS include some useful information!  >:(
Best Regards, Chris
« Reply #18 on: September 04, 2018, 06:23:34 pm »
The only faults he has are in his circuits. How this man-child got close to electricity is a mystery.
OK, here's some useful information:
Oh, and I believe the word is "snarky".
Offline T3sl4co1l
Offline Gyro
« Reply #20 on: September 04, 2018, 06:38:04 pm »
No it's sarky, short for sarcastic in the UK... and I still see no useful contribution.
Best Regards, Chris
Offline iainwhite
  • Measure twice...
« Reply #21 on: September 04, 2018, 06:38:59 pm »
Sarky is a British-English slang word for "sarcastic"
« Reply #22 on: September 04, 2018, 06:39:53 pm »
Well it's what we called Nicolas Sarkozy.
« Reply #23 on: September 04, 2018, 06:42:03 pm »
I disagree, I provided useful nutritional information. Treez is a bit sugared-up and needs to cut down on the carbs I think.
Offline Gyro
« Reply #24 on: September 04, 2018, 07:33:31 pm »
Best Regards, Chris
