IanB is right (as usual). The advantage to a wall plug-in USB charger might be faster charging. That's only true if the wall plug-in USB charger supports a higher charge rate, and if the device you're charging can accept current at the higher rate. Furthermore, fast charging isn't necessarily better than slower charging. Obviously, fast charging is better if you don't have time to wait, but slower charging generally heats things up less and may be a bit gentler on the batteries.
Generally speaking, we're talking about a slow rate of about 0.5A, and a fast rate of 1 to 2A. The difference is a factor of 2 or 4. Not huge, but definitely noticeable if you're standing around waiting for the charge to finish.
If you're not in a big hurry, and if the computer would be switched on anyway, you're not doing any harm by using a computer.
