I ordered many power supply bricks (230V AC -> 12V DC) from a chinese supplier, and I'm very satisfied with them except that very few units (about 1 of 200) are defective.
I'm ok with that but am curious about what goes wrong in the defective units. Both have the same issue : plugging them immediately triggers the mains breaker. Checking the AC input with an ohm meter shows a resistance (about 500 ohm) between one of the AC pins (phase/neutral) and earth. Resistance only shows up in 1 direction otherwise it's infinite (like a diode).
I haven't opened the plug pack yet since they're welded.
Do you know what common failure in SMPS power packs usually causes this ?
