Author Topic: Power cords with wires impossible to solder  (Read 7449 times)
Offline SnipTheCatTopic starter
  • Country: th
« on: October 03, 2016, 09:13:12 pm »
I have been asking myself for a long time about this and didn't really find answer, and since I make my own power cords I am less faced with the problem than before.
The problem is that those power cords seems to have pretty dark wires (multibrain), When you try to solder you can some bubling and a lot of dirt as you cet with enamelled wires, but here the soldering doesn't stick to it. If you are patient enough you may have something that seems soldered, but usually you pull it apart quite easily. I have tried flux, no help, tried higher soldering temperature, no help...
Anyone knows any magic for those?
Online Mechatrommer
  • Country: my
  • reassessing directives...
Re: Power cords with wires impossible to solder
« Reply #1 on: October 03, 2016, 09:21:07 pm »
scrap off the blackish thing with knife..
Offline Monkeh
« Reply #2 on: October 03, 2016, 09:22:14 pm »
Get some decent cables.
Offline Monkeh
« Reply #3 on: October 03, 2016, 09:28:02 pm »
s/high quality/normal quality/
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #4 on: October 03, 2016, 09:35:43 pm »
To increase flexibility, some wires are spun around, or interleaved with fibre/glass threads,  these are notoriously hard to solder, and are designed to be welded or crimped - not soldered.
Don't ask a question if you aren't willing to listen to the answer.
The following users thanked this post: SnipTheCat
Offline stj
« Reply #5 on: October 03, 2016, 09:57:03 pm »
maybe using crimp bootlace-ferrules would help.
if you do, get a 6-sided crimp tool - not a 4-sided one.
like this:
http://www.ebay.co.uk/itm/141578568204
The following users thanked this post: bitslice, SnipTheCat
  • Country: th
« Reply #6 on: October 03, 2016, 10:17:20 pm »
Thanks for all the quick replies :-) I would think of the oxidized/impure copper... I have also seen those cables interleaved with fiber, they are also a pain to solder. I guess I'll just get decent cables instead to try to reuse crap... What is sad is that these had preddy decent gauge (~1mm^2 per wire)
 About scrapping the dark parts or even trying vinegar+salt I had very very little success
« Reply #7 on: October 03, 2016, 10:24:04 pm »
Sometimes a solder with a more aggressive flix can save the day, along with a much hotter iron.
A bit of a fiddle with some snippets can usually find a solution.  ;)
When all else fails scraping the conductors to shine them up can and does sometimes work or you'll have to resort to crimping ferrules or some other suitable terminal.
Avid Rabid Hobbyist
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #8 on: October 03, 2016, 10:25:46 pm »
Probably copper coated aluminium (CCA) which is evil.
Chop it & replace with proper wire.
Day Job: Mostly LEDs
The following users thanked this post: SeanB, SnipTheCat
Offline bitslice
« Reply #9 on: October 03, 2016, 11:19:49 pm »
like this:
Thanks for that,
I was looking for a bootlace crimper but didn't realise they did hex versions in that size  :-+
Offline Audioguru
« Reply #10 on: October 03, 2016, 11:37:06 pm »
Copper wires that have been wet for a long time have black copper that is hard to solder to.
  • Country: th
« Reply #11 on: October 04, 2016, 11:29:59 am »
I have the feeling that's what it was... anyway, tossed it away and got proper cable ;-)
Offline Lightages
  • Canadian po
« Reply #12 on: October 04, 2016, 03:20:16 pm »
I have also seen many cables with copper coated steel wire.
Offline rob42
  • Country: aq
« Reply #13 on: October 04, 2016, 04:50:46 pm »
try aspirin or other active flux
Offline george.b
  • Country: br
« Reply #14 on: October 04, 2016, 05:16:36 pm »
Aspirin?  :wtf:
Offline Len
« Reply #15 on: October 04, 2016, 05:38:17 pm »
Aspirin?  :wtf:
If soldering is giving you a headache, take aspirin and use a good flux.  :)
DIY Eurorack Synth: https://lenp.net/synth/
Offline Monkeh
« Reply #16 on: October 04, 2016, 07:02:02 pm »
Aspirin?  :wtf:
Works really well. Say goodbye to your tip, too.
Offline electr_peter
  • Country: lt
« Reply #17 on: October 04, 2016, 08:01:54 pm »
Metal strands can be made out of steel - check with magnet. Or it can be CCA, as Mike mentioned.
Either way, I would toss this cable out and get proper cable with copper strands. Copper clad aluminium or steel is not good in mains power cables (it is a desperate cost saving measure from a manufacturer, which results in very high resistance cable).
Offline stj
« Reply #18 on: October 04, 2016, 09:14:25 pm »
could make a good flexable heating element!  :-DD
Offline george.b
  • Country: br
« Reply #19 on: October 05, 2016, 07:15:07 am »
No kidding? Gotta try that one, sometime. Who knows when such a trick might come in handy...
Offline rob42
  • Country: aq
« Reply #20 on: October 05, 2016, 01:46:13 pm »
Aspirin?  :wtf:
its just acetylsalicylic acid, you can use any other weak acid, like orthophosphor, acetic (vinegar), formic etc.
or weak organic (used in no-clean fluxes): palmitic, oleic, succinic, glutaric, paraffine / stearine, glycerine...
« Last Edit: October 05, 2016, 02:12:32 pm by rob42 »
Offline george.b
  • Country: br
« Reply #21 on: October 06, 2016, 02:53:11 am »
Aspirin?  :wtf:
I know, but I thought it would decompose at soldering temperatures, didn't imagine it'd work!
Offline helius
« Reply #22 on: October 06, 2016, 03:09:10 am »
It may decompose, but it is an ester, so if it hydrolyzes at the ester bond it will produce two other acids: salicylic and acetic. I think water soluble fluxes frequently contain similar esters.
The following users thanked this post: george.b
Offline george.b
  • Country: br
« Reply #23 on: October 06, 2016, 04:06:23 am »
Aha, I see. Chemistry is not my strong suit ;D thanks!
Offline johansen
« Reply #24 on: October 06, 2016, 04:18:21 am »
Some really cheap cables use unrefined recycled copper. Since many recycled copper comes from scrap wall sockets or power strips, they have high phosphorous and beryllium content, which makes them hard to wet by solder.
Solution: buy high normal quality cables with either low recycled content or refined recycled content. You will not see crappy copper in Longwell or Volex cables.
Edit: s/high quality/normal quality/g
If they add the phosphorous as some kind of deoxidiser or something, that might make sense.
But its hard to believe there would be enough beryllium in there to prevent it from soldering. unless they dumped a metric ton of relay contacts in with the 10 tons of copper. but i don't think that would be enough.. also if someone did have a metric ton of relay contacts, it would be recycled for the beryllium and silver, not dumped in a copper melt.
but if someone were to melt down 100 tons of power strips.. there would be enough brass in with the copper cord to raise the resistance to unreasonable levels.. however, still no beryllium
I have run across some 10 ohm, 6 foot long, iec power cords. not making that up. the servers they came with only pulled about 100 watts, so they would have survived, and their resistance was discovered after finding one of them was open circuit. the wires were not magnetic, had a color somewhere between brass and light brown..
« Last Edit: October 06, 2016, 04:21:48 am by johansen »
