Author Topic: Power Delivery issues with boost converter  (Read 1021 times)
Offline tyguy2Topic starter
« on: July 18, 2019, 11:26:08 pm »
Hello all,
I've recently designed a 5v rail that takes a minimum of 3.3v from a battery and steps it up to 5v, with a maximum current draw of 500ma (schematic attached, here's the part https://www.digikey.com/product-detail/en/maxim-integrated/MAX1522EUT-T/MAX1522EUT-TCT-ND/6680188). I'm already imbedded the design into a PCB, but I'm getting strange voltage sags when I try to draw anything over around 200ma. Does anyone have any ideas on how I can fix this without having to rerun a new PCB?
[Sarcastic comment] clever joke [/sarcastic comment]
Bitcoin:
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
Offline StillTrying
  • Country: Broken Britain
Re: Power Delivery issues with boost converter
« Reply #1 on: July 19, 2019, 12:21:32 am »
I can't see anything obvious from the data sheet, are you sure the input 3.3V isn't dropping.
« Reply #2 on: July 19, 2019, 01:34:43 am »
I've checked that, and I'm not getting any issues with that either. 3.3v comes directly from a LiPo
Bitcoin:
Offline Audioguru again
« Reply #3 on: July 19, 2019, 02:05:30 am »
Your 3.3V Li-PO is almost dead. It is 4.2V when fully charged and is 3.7V when half-charged. it should be disconnected and re-charged when it is 3.2V.
Are you drawing 5A from the 3.3V Li-PO? That is 5A x 3.3V= 16.5W. Maybe 1.6W is wasted on heat then the 5V output will be 15.5W/5V= 3.1A but a Li-PO that is almost dead cannot produce the original 5A.
« Reply #4 on: July 19, 2019, 03:12:10 am »
No, this Lipo is fully charged to 4.2v, I'm just having it operate down to the drop off voltage of the battery. I said I was drawing 500ma, not 5A.
Bitcoin:
Offline Psi
« Reply #5 on: July 19, 2019, 03:27:12 am »
D9 (DB2J310) is only rated to 200mA absolute max
« Reply #6 on: July 19, 2019, 04:21:31 am »
 :palm: Right in my face the entire time. Thanks!
Bitcoin:
Offline MagicSmoker
« Reply #7 on: July 19, 2019, 10:13:10 am »
Yeah, that is a problem, but not one that would cause Vo to sag. A more likely cause is saturation of the boost inductor. It needs to withstand a peak current considerably higher than the average dc input current (e.g. - 40-100% more) without losing too much inductance in the process.
EDIT - corrected "wouldn't" to "would"
« Last Edit: July 19, 2019, 03:33:05 pm by MagicSmoker »
