yes, your calculations look right. Is there any particular reason to go with such a low resistance trimmer though? if it's feeding the bias if an op-amp, a 10K trimmer would be good enough, and you may even get away with 100K. The benefit of this is it reduces power consumption, and the power dissipated in the trimmer. I'd try and pick as high as a value that you can get away with. Op-amp inputs tend to be in the megΩ range, so you shouldn't need too low a value trimmer. I'd try 100K, if it's just for a voltage divider to an input.
