Author Topic: Power Management  (Read 1585 times)
Offline desowin
Power Management
« on: March 01, 2011, 10:59:53 am »
I'm rather complete newbie to power supply related issues, basically I know about the 7805 and I've watched EEVblog #139 - Let's Select a DC-DC Boost Converter
I'm searching for solution which would handle following:
-AA (2 or 4) battery input
-car cigarette lighter input
-3.3 V output
-5 V output (but that's just "extra", not mandatory)
If the device is plugged into car cigarette lighter, it should be powered from there - if not, then it should be driven from batteries, integrated charger solution (in case the cells were NiMH or NiCd) is not required
I heard there're PMIC solutions that could handle that, but either I'm searching wrong, or it's called somehow different.
Offline scrat
Re: Power Management
« Reply #1 on: March 01, 2011, 11:18:22 am »
I know National Semi has good online tools, but someone knows better than me. However, I'd try with a parametric search on a semiconductor manufacturer site, as a start.
One machine can do the work of fifty ordinary men. No machine can do the work of one extraordinary man. - Elbert Hubbard
