I would like to create a circuit that monitors a 48V power rail that feeds an audio amplifier. When the voltage begins to drop at power-off I want the circuit to pull the amplifier mute pin to ground.
I have thought up this circuit using a open drain comparator (output is connected to the mute pin with 10K pull-up) and made a
Falstad sim. I would appreciate comments if my design seems sensible or there are any traps I might not have considered?
Note that the amp is powered directly from the 48V rail, but the comparator will be powered from a regulated 3.3V that comes off the 48V rail. I believe by the time the comparator looses power, the amplifier will not be operational as it appears to not start below about 18V.
