Good afternoon,
I found python script in Data Logging of Power Profiles from Wireless IoT and Other Low-Power Devices to stream digitized current readings over a LAN connection to an external computer. However when I run it I get values that don't match the values I get on the front panel of device. I have tried to decode data that I get but it won't work. Is there something that needs to be modified in these scripts? I provided scripts in text format.
Thanks in advance
Best regards,
Vukasin Pavkovic
