Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
555 square wave help
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 555 square wave help (Read 1957 times)
electron_misfire
Contributor
Country:
on:
April 05, 2014, 06:13:50 am »
I'm designing a simple square wave generator.
I'm using a 555 timer in astable mode.
My problem is that whenever I power the circuit it turns on the after a few seconds turns off and never goes back on again.
Would anyone have some advice or help?
Logged
Simon
Global Moderator
Country:
Did that just blow up? No? might work after all !!
Re: 555 square wave help
Reply #1 on:
April 05, 2014, 06:18:12 am »
Is the top resistor value 1R ?
1000uF ? you need to read the datasheet thoroughly, there is a limit to the discharge current allowed in pin 7
Last Edit: April 05, 2014, 06:22:53 am by Simon
Logged
electron_misfire
Contributor
Country:
Reply #2 on:
April 05, 2014, 06:48:43 am »
Ok I've swapped the 1r resistor and 1000uf cap. It's working now thanks
Logged
Simon
Global Moderator
Country:
Reply #3 on:
April 05, 2014, 07:00:38 am »
I think that 1R needs to be 1K minimum (check the allowed discharge current) and with 1000uF and 4K that would have given a 4s discharge time.
Datasheets have all the formulas, give it a thorough read.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
