"bidirectional" seems to get me expensive devices that can actually send data in both directions across the isolation gap. What i want is to be able to send data in a single direction per channel, but that each channel should be in opposing directions! ie instead of having both LED's on one side, and both LDDs/transistors on the other, the device has one LED & one LDD/transistor on each side?
