Author Topic: power supply, I have only common cathode diodes  (Read 1081 times)
Offline stefonTopic starter
« on: December 20, 2019, 11:21:17 am »
stupid question... I have only common cathode diodes schottky diodes.
Can I do something like that to get symmetrical power supply?
Offline MagicSmoker
Re: power supply, I have only common cathode diodes
« Reply #1 on: December 20, 2019, 12:24:17 pm »
You sure can.
« Reply #2 on: December 20, 2019, 02:20:50 pm »
well, this is how it looks... "-" is weird... why?
edit: OK, I think I know.... reverse voltage of one schottky diode is only 30V and when I connected both 12V trafos, there is 40V peak to peak
« Last Edit: December 20, 2019, 02:41:16 pm by stefon »
Offline StillTrying
  • Country: Broken Britain
« Reply #3 on: December 20, 2019, 03:01:45 pm »
Looking at the scope that explanation doesn't make sense to me, but I can't explain why just 1 half of the  -ve's cycles is floating about either. :)
Offline Jwillis
« Reply #4 on: December 22, 2019, 05:00:56 am »
Looks like you have one bad diode that isn't recovering very well.
Offline ArthurDent
« Reply #5 on: December 22, 2019, 05:21:50 am »
If the circuit is as shown and you have no real load, it may just be reverse leakage on one diode. Try just touching a 1K resistor across the output and see if the waveform returns to normal. The circuit may work just fine with a normal load but the scope you're using may be very high impedance and the diode has enough reverse leakage to show some voltage at this really low current load. I would still check to see which diode is causing this and perhaps replace it if you have spares, just in case.
https://www.tutorialspoint.com/semiconductor_devices/semiconductor_devices_leakage_current.htm
Offline schmitt trigger
  • Country: mx
« Reply #6 on: December 22, 2019, 05:29:42 am »
 :-+ What ArthurDent said
Offline andy3055
« Reply #7 on: December 22, 2019, 07:24:02 am »
If you need -ve voltage, should you not reverse the diodes in the bottom half of the circuit?
Offline StillTrying
« Reply #8 on: December 22, 2019, 12:20:03 pm »
I think it's more to do with capacitance across the transformer windings rather than anything to do with one of the diodes. :popcorn:
A small load, even ~10k across the rectified -ve supply's DC output would probably fix it.
« Last Edit: December 23, 2019, 10:05:06 am by StillTrying »
