Hi Everybody,
I assembled a simple 555 astable multivibrator (the design with the two diodes) which was powered by a power supply (in this case a tektronix PWS4323) @9V on a breadboard. The signal appeared modulated inside a sinusoidal wave at a frequency of 60Hz (The frequency of the mains in my country).
The circuit is as follows:
I tried with different C1 capacitors and results were similar (when the values were close to the 60Hz you would get a distorted square wave, but once they differed significantly a square wave pattern is embedded on a carrier 60Hz Sine Wave). The partern was the following:
When hooking to another generic power supply the result was like this, for the same circuit and same DDP applied (9V) the result was:
The envelope for the "GOOD" power supply had some variation:
I posted because the variation that I would classify as ripple, was in my view also coupled to the mains frequency.
When I tested the Tektronix Power supply with my fluke 179 and fluke 87V, there was no AC signal at all (A couple of millivolts to be precise, but nowhere near the signal seeing on the scope).
Anybody could explain why the power supply is behaving that way? The voltages and currents are spot on on the Tek Power supply and it passes self test. Probes on scope 1X, DC coupled (tried AC and same happened).
Thanks!
