My project is this - I am sampling an acoustic piano, which involves recording each key at a wide range of velocities, from very quiet to very loud. To accomplish this, I've enlisted the aid of a DC linear motor.
Got one a few years ago (
http://moticont.com/DDLM-019-070-01.htm) and I used the software that accompanied the cheapie power supply I got (
https://tekpower.us/tp3005p.html) to create programmed steps for the DC motor. I calculated the necessary voltages to get the velocity / loudness levels I wanted, and put them in a CSV document that the software could input. The higher the voltage, the greater the force that the motor puts out, the louder the piano key is "played" by the robot sampler.
Worked great! I was able to automate the process of sampling each key. However, the motor wasn't quite powerful enough to reach the highest velocity / loudest level that I wanted. No fortissimo!
So, I just upgraded to a more powerful motor (
http://moticont.com/DDLM-038-051-01.htm). Problem is now when I try to activate the motor past a certain level, the voltage starts to drop. My cheapie power supply can't provide enough juice to get to the upper reaches of my new motor. So, still no fortissimo.
I really have no idea of the power requirements of the motor. Seems stupid, I know, but I just don't. The Moticont website offers no insights beyond this doc -
http://moticont.com/pdf/linear-dc-motor-force-calculation.pdf I am the classic jack-of-all, master-of-none, and my brain freezes up when confronted with real stuff like this.
So, I am left to simply
guess that if my 30V, 5A power supply won't cut it, maybe a 50V 20A unit will. Another cheapie -
http://www.volteq.com/programmable-dc-power-supply-hy5020ep-0-50v-0-20a-with-arduino-nano.htmlSo, questions are this...
- Would this power supply be sufficient to access the full range of the motor?
- Will I be able to figure out how to program the thing?
I do not know the first thing about Arduino. I am not an electronics guy, not a programming guy, so I've got two strikes against me from the outset. The PS website says some "sample code with a rich set of features" is provided. On Monday, I'll give them a call and ask a few questions.
But I figured I'd post here to see what you think about question #1!
Thanks!
