Author Topic: iBook G3 GPU rework/reflow with hot air  (Read 3851 times)
Offline nashyboyslimTopic starter
« on: July 25, 2012, 09:53:32 am »
Hello,
Not sure if I'm posting this in right place but hey ... basically I'm hoping Dave has created a tutorial on how to reflow/rework the GPU on the logic board of an iBook G3 laptop using hot air ... or which ever is the best easiest option - and if you haven't Dave could/would you do one.
Many thanx in advance
Chris. ( Newbie )
Offline kripton2035
Re: iBook G3 GPU rework/reflow with hot air
« Reply #1 on: July 25, 2012, 10:21:52 am »
I've done some before, it doesnt work everytime... but it may work sometimes...
and today, repairing an ibook g3 is not worth it ...
Offline Rerouter
« Reply #2 on: July 25, 2012, 10:30:01 am »
while i have never myself used one, i believe it would involve masking off the other components so as not to effect them, then go over it using temperatures suggested in the few repair stories,
Offline amyk
Offline poorchava
  • Troll Cave Electronics!
« Reply #4 on: July 26, 2012, 11:26:54 pm »
Some people used to reflow PC graphic cards in kitchen oven :)
Offline DaveW
    • WattCircuit
« Reply #5 on: July 27, 2012, 07:31:23 am »
I've done a few PS3 boards, which looks like a similar problem. It's best to first mask off the components around whatever you're reflowing, kapton tape works nicely as it's highly heat resistant. Try and keep the static down when you do this though. Then, as it's a multilayer board with a lot of copper planes, it's easiest to take the whole board to a little under the solder reflow temperature, say 180 degrees C or so; being careful to make sure any plastic parts don't melt! Doing this with a toaster oven or kitchen oven is normally pretty straightforward, but the temperature readings on these can be way out, use a thermocouple or similar to read the temperature!
You can then take the board out and use a hot air gun to heat up the part that needs reflowing. The cheap hot air soldering tools that come up on here frequently work well for this. You can take the part up to the full reflow temperature and it should seat back down again.
Generally, you'll then have one of three things happen. It'll either not work and never work again, which means you've heated it up too much. Or it'll work for a while, and then break again. This means you've got to do the same process again, but being a bit more aggressive with the heat in the final stage. Or it'll be fixed!
« Reply #6 on: October 07, 2012, 07:29:03 pm »
Hi Guys,
Many thanx for all of your replies, I will try all of your suggestions .. and report back if I have any success.
Cheers,
nashyboyslim.
