Author Topic: Power supply transient overvoltage  (Read 12574 times)
Offline todor96Topic starter
  • Country: cs
« on: September 01, 2017, 01:00:22 am »
Hi all,
I recently got myself a Baku BK-1502D+, a cheap Chinese 15V/2A power supply. I've noticed that when I turned it on, my computer monitor turned off for a second and than went back on. I hooked up my oscilloscope to the output of it and directly to the mains. What I have discovered is that there were transients on both signals, for about 100us, about 140V peak to peak on the mains and 60V on the PSU output. What could be the possible cause of that, and what could I do to fix it?
Thanks!
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Power supply transient overvoltage
« Reply #1 on: September 01, 2017, 07:23:09 am »
Do you have a Dell monitor perhaps?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: September 01, 2017, 07:30:14 am »
Nice capture of in-practice EFT (electrical fast transient) bursts!
Seven Transistor Labs, LLC
The following users thanked this post: todor96
Offline tautech
« Reply #3 on: September 01, 2017, 07:48:30 am »
Tim's right but its source ?
Set the Trigger for rising and do the first screenshot again but this time switch the PSU from the wall, not it's internal switch.
It's a linear PSU so they're won't/shouldn't be any switching noise.
The long gray leads go to the 2N3055 pass bipolar.
This Russian page even has the schematic.
http://ziblog.ru/2011/03/02/blok-pitaniya-baku-bk-1502d.html
Edit.
After further study........no common mode mains input filter or X or Y suppression caps.  :--
« Last Edit: September 01, 2017, 08:00:10 am by tautech »
  • Country: cs
« Reply #4 on: September 01, 2017, 08:16:47 am »
No, I have an LG.
Sent from my Nexus 5X using Tapatalk
Online Ian.M
« Reply #5 on: September 01, 2017, 08:36:26 am »
Its a linear transformer based PSU - it doesn't *NEED* a common mode filter or X or Y capacitors.   However the transformer is probably marginal and is saturating at switch-on.   Also, there may be a common mode mains supply impedance problem, especially if your bench runs off an underrated circuit or you use a lot of multi-socket extension leads.
Its possible adding a soft-start circuit would help e.g a suitable NTC thermistor for the full load primary current + a time delay relay to bypass it after a second or so, so it can cool down again ready for the next switch-on.
  • Country: cs
« Reply #6 on: September 01, 2017, 08:40:57 am »
I didn't even realize the trigger was set to falling edge :palm:
I recreated the setup, this time with rising edge trigger, and no matter if I switch it on on the switch or plug it in and out directly, the same thing occurs.
How bad of a deal is it? Could this damage circuitry attached to it?
EDIT:
I forgot to add, the same thing happens when i switch it off.
Guess it's the right time to learn something more about power supply design  :)
Thank you very much for your effort.
« Last Edit: September 01, 2017, 08:44:16 am by todor96 »
  • Country: cs
« Reply #7 on: September 01, 2017, 08:52:14 am »
I will investigate that. I don't use a lot of extension cords, in fact, to rule that out, I unplugged the extension cord it was in and plugged it directly to the outlet when I was testing.
Good idea  :-+
Offline tautech
« Reply #8 on: September 01, 2017, 09:32:11 am »
EDIT:
Possibly but we need to know where it's originating from or it's just induced into your probing technique.
As you normally use some local bulk capacitance on a DUT that might take care if it, try something with 1k uF across it and see if it does.
Edit.
Looking again at the schematic, the addition of a ceramic cap might help grab some of that high speed rubbish.
« Last Edit: September 01, 2017, 09:45:23 am by tautech »
  • Country: cs
« Reply #9 on: September 01, 2017, 02:39:55 pm »
EDIT:
Edit.
I will try that and post the results. Thanks again.
