The notes above on power are the bit the untangles it, I think. If it's a 300 watt supply, you can have 60v at 5A, or 40v at 7.5A, all limited a bit by the particular design. Ask the folks who made it for the details.
But to me that seems huge. My favorite supply is 20v at 500mA, and my second favorite supply is 20v at 2A. I rarely use them above 10v or 10's of mA. They are valuable to me because I get voltages I can control down to a small fraction of a millivolt, very accurately. That's my thing.
For audio circuits, +-15v (more or less!) at well under an amp from the Siglent is usually fine. Power amps probably need their own supply, but basic testing might get by with +-30v at modest current so I don't blow it up again.
IOW, if you're not sure what you're going to be doing, start modest, and eventually you'll know what you need for your second supply. 300W, for example, is beyond modest for most purposes.
If you do know what you're going to be doing, that will answer the question.
