Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Power supply wine when running led contoller
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Power supply wine when running led contoller (Read 1420 times)
shiftline
Contributor
Country:
on:
May 19, 2016, 06:16:13 pm »
I bought this susay 100w 12v 8.5a power supply for my DIY LED light
It powers a TV420 contoller which outputs to the different led channels
Everything works except for this annoy whine outputted from the power supply
How can I fix this?!
Logged
Wirehead
Regular Contributor
Country:
Re: Power supply wine when running led contoller
Reply #1 on:
May 19, 2016, 06:21:31 pm »
Can you put a capacitor on the input V+ V- of the controller? Probably the PWM'ing is causing spikes on the supply rail.
Logged
"to remain static is to lose ground"
shiftline
Contributor
Country:
Reply #2 on:
May 19, 2016, 07:49:17 pm »
I will try it. Do you have a recommendation of what size to use?
Logged
ali6x944
Frequent Contributor
Country:
Reply #3 on:
May 19, 2016, 08:54:44 pm »
How much current dose the led driver draws from the supply , because some supplies will make a high pitch wine when high current is drown due to the fact that it shift in frequency and the increased duty cycle which is some times in hearing rang.
Logged
shiftline
Contributor
Country:
Reply #4 on:
June 20, 2016, 06:00:05 am »
I ended up finding a different supply but I'm still curious to test this to find out the cause. I'll put a meter on it later and see what is drawing
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
