For my project, I'm looking for inspiration for a simple power supply with a constant and stable (no switched-mode) voltage of about 0.3V (could be 0.4V or 0.5V as a last resort) but with a current of at least 1A - 1.5A preferred.
I know that I can build such a power supply with an LM317, but then I need a negative voltage on the "Adjustment" pin. Could I ask for suggestions on how else I can generate such a low voltage, but at the same time provide a current flow of at least 1A? (1.5A preferred)
Thanks.
