Author Topic: Power switch using LTC4412; P ch. MOSFET does not open  (Read 3389 times)
Offline zzattackTopic starter
« on: December 01, 2015, 03:22:34 pm »
I built a power switch circuit based on a LTC4412 that will disconnect my battery when an auxilary power source is available. Schematic is built exactly as presented in the data sheet:
The wall adapter input, when available, is a regulated 6V DC supply. The battery is a single-cell lipo that should be between 4.2-3.7V. The load goes toward a 3.3V low-dropout voltage regulator.
Testing the operation of this circuit, I found that with just the battery hooked up, the LTC4412 pulls its gate low and Vbat is fed into the regulator. With the auxilary source enabled I verified that the gate pin measures a high. So far so good. Now for the problem: the MOSFET does not seem to open completely. I'm measuring 6V at both the drain and gate pins, but the PSU also hits the current limiter and I read about 5.5V at the source pin (thus going into the battery!). I've replaced the MOSFET but the problem remains.
So, my best guess is that I did not choose a correct MOSFET for the job. The part I'm using is the NDS332p, with important parameters
VDS(MAX): -20V
VGS(VT): -0.6V
RDSon: 0.4Ohms typical
The VGS(VT) seems most important and should work with the 6V-4.2V difference between aux and battery supply.
How can I figure out what's happening here?
Offline homebrew
Re: Power switch using LTC4412; P ch. MOSFET does not open
« Reply #1 on: December 01, 2015, 07:35:53 pm »
Did you put the FET in reverse? (Accidentally swapped drain and source?)
Would at least explain the behavior as it would operate as a diode (but in reverse) ...
Just an idea ...
Offline Radiohead
« Reply #2 on: December 01, 2015, 08:23:59 pm »
The Mosfet does not behave as an ideal diode, as it has an internal parasitic diode between drain-source. As you have noted, it charges your battery through the parasitic diode when the auxilary power source is connected. Use back-to-back mosfet configuration for ideal mosfet operation and connect CTL to GND, as described in the datasheet. See figure 4 and read "Ideal Diode Control with a microcontroller" above figure 4.
Offline homebrew
« Reply #3 on: December 01, 2015, 08:48:34 pm »
Sorry, äh, no!
That is the REASON that this part exists. It should PREVENT reverse current flow! However FET does behave as a diode in one direction. Hence you could not turn the load off in that configuration and hence you need the back-to-back FETs to have that feature if desired. Not for the normal behavior of switching between two supplies...
« Reply #4 on: December 02, 2015, 03:03:30 pm »
I truly thought I had moved past this level of stupidity but must shamefully admit this was indeed the cause.. Thanks!
