Author Topic: 4026 chip - counterpart for common anode displays  (Read 1933 times)
Offline BurczykTopic starter
« on: March 21, 2018, 03:04:12 pm »
Hello.
I am experimenting with 4000 series logic chips. I tested some johnson counters and divide-by-n counters. Now i wanted to test my 4026. But it turned out all my 7 segment displays are common-anode type. If i was to interface my IC with these displays i would have to use 14 transistors. Can someone point out a common anode 7 seg. display driver IC, that would be similar to the 4026?
all my friends have off switches
Kabid-Zopan test equipment collector
Offline fourtytwo42
  • Interested in all things green/ECO NOT political
Re: 4026 chip - counterpart for common anode displays
« Reply #1 on: March 21, 2018, 04:25:41 pm »
You could use a buffer chip such as the ULN2003 etc that will both invert your signals and provide the drive current you probably need anyway.
Offline Chris-IP5
« Reply #2 on: March 21, 2018, 09:07:01 pm »
I think the 4000 series expects common cathode 7-seg displays. I can't see any display driver IC in that series for common anode.
My approach would have been to have separate counter and display ICs... but sadly not a solution for you if you only have common anode display.
One of the other logic families might have a suitable display IC.
Offline DC1MC
« Reply #3 on: March 21, 2018, 09:33:12 pm »
Like 74LS47  :-// ?
Offline Chris-IP5
« Reply #4 on: March 21, 2018, 10:59:00 pm »
Yes that will work with common anode display.
Connect LT (pin 3) and RBI (pin 5) pins to +5V. Input pins 5V max of course.
That is a BCD type so you need to provide a BCD input (4 wires).
Is this helpful?
« Reply #5 on: March 23, 2018, 12:25:54 pm »
Yes, thank you for all your replies.
I managed to find a small common cathode display at the bottom of my parts box, i will use that for my experiments.
