Author Topic: Power transformer, low capacitance between winding  (Read 2072 times)
Offline GigaJoeTopic starter
« on: December 13, 2018, 03:20:51 am »
Hi everyone,
I wonder: Here some rumor, that, as lower capacitance between winding it better,  especially some magic transformers in use inside some extra magic Fluke devices that no one able to reproduce.
So what is this actually?  Is it a new hi-end thingi, like a special lamp sound, and diamonds interconnect cables ?
I my understanding it just HF parasitic able to sneak trough , and extremely efficient way  LCR, common mode filter , chokes ... trans are the last thing ..
I'm missing something ?
Offline Jwillis
Re: Power transformer, low capacitance between winding
« Reply #1 on: December 13, 2018, 06:14:05 am »
Theirs going to be a trade off between capacitance and leakage inductance.More capacitance less leakage inductance.Less capacitance more leakage inductance.
This could probably explain it better than I could.
https://coefs.uncc.edu/mnoras/files/2013/03/Transformer-and-Inductor-Design-Handbook_Chapter_17.pdf
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: December 13, 2018, 09:50:31 pm »
Depends on application.
Audio "woo" aside, there are real reasons to optimize winding self-capacitance and interwinding capacitance.  These go hand-in-hand with the leakage inductance as well, the combination of which sets the cutoff bandwidth of the transformer, Fc = 1 / (2*pi*sqrt(LL*Cp)), and the ratio of which sets the characteristic impedance of the transformer, Zo = sqrt(L/C).
The relevance of the impedance is not a power-matching one -- it helps, but it's not about power transfer because an ideal (LC, no R) transformer does not dissipate power!  It does, however, facilitate power transfer between a source and load of similar impedance.
The impact is not so much power transfer, but bandwidth.  The further the source/load impedance is from Zo, the less the bandwidth is.
Regarding inter-winding (isolation) capacitance, this is similarly unavoidable, but always undesirable.  It doesn't interfere with your signal if you keep the signal fully differential (consider, if you model the total capacitance as half and half connected between either end of the windings, then the capacitance cancels out perfectly, differentially), but that's often inconvenient, and normal-mode applications are common.  You can at least improve it, by adding a common mode choke which increases the common-mode impedance at high frequencies, one which is also well enough damped not to cause problems at the resonant frequency.
If you need low capacitance, you must choose a high Zo (gives high LL, low Cp) and high cutoff frequency (low LL and Cp).  Having to prioritize capacitance may mean making compromises with the circuit design, or its capabilities.  For example, high LL discourages flyback DC-DC converters, so you might have to work with a resonant converter instead.
Another example: medical isolation transformers, with very low capacitance (<100pF?) while operating at mains frequency.  The Zo is made very large compared to the load resistance (which, say for a 120V 10A isolation transformer, is below 12 ohms to maintain good regulation).  This is acceptable, as long as Fc is kept high (which is what is done: it's in the ~kHz range for most mains transformers, tens or hundreds of times the operating frequency -- so Zo can be similarly mismatched with acceptable results).
Seven Transistor Labs, LLC
« Reply #3 on: December 13, 2018, 10:19:26 pm »
Thanks Tim,
So ....
If we speaking about signal isolation transformers, then,  that occurrence of capacitance are fully understandable for me; so to  in overall interfere with a signal to transfer ...
But what I do not understand a reason meticulously follow on low capacitance for a regular power transformer , where secondary winding going to bridge, then chain of caps, then VR ; then caps again ... .... even primary has EMI filter most often.   -   That particular moment  I matching with audio hi-end fanzy ; and it simply redonkeylous
Offline T3sl4co1l
« Reply #4 on: December 14, 2018, 12:55:56 am »
Right, there isn't much point in a low capacitance mains transformer, outside of isolating ground current (which is why medical transformers exist).  More important is an electrostatic shield between windings, to limit the influence of mains noise and surges upon the secondary.
A capacitance to ground is much less troubling than a capacitance to a noise source.
SMPSs are by far the more demanding application.  Or signal transformers for precision RF applications.  It's still relevant in low-level audio applications, but is an easier problem to solve.
