Author Topic: Powered from "wall wart" or USB?  (Read 2300 times)
Offline Matir
    • SystemOverlord
« on: May 06, 2017, 09:59:51 pm »
How do devices that can be powered either from a wall wart or from USB work to avoid feeding power back to the USB host?  Take a powered USB hub for example -- many will operate with just the USB input, but can also take a "wall wart" SMPS to provide higher current supplies.  While super cheap ones just tie the two +5V lines together, I imagine there's a more proper way to do this.  Obviously, 2 diodes would work, but then you have a diode voltage drop, which isn't really usable to power USB from USB.
Offline testian
Re: Powered from "wall wart" or USB?
« Reply #1 on: May 06, 2017, 10:10:04 pm »
I haven't looked into one but it should be possible with mosfets like in reverse polarity protections.
Offline jeroen79
« Reply #2 on: May 06, 2017, 10:16:12 pm »
You can get connectors with a built in NC switch that is connected to the USB 5V.
When the connector is inserted it will disconnect the USB power and take power from the external source.
Online mariush
« Reply #3 on: May 06, 2017, 10:20:15 pm »
Most just do two diodes.
Some probably could have a circuit which which is powered from the smps side, disconnects the usb side and connect the smps side with some mosfets or something like that.
Look into ideal diode controllers or something like that.
Online Zero999
  • 0999
« Reply #4 on: May 06, 2017, 10:37:54 pm »
USB sockets always supply power and plugs draw power. I've never seen a device with more than one USB plug before, so that situation doesn't arise.
Normally the "wall wart" used to power something like that has a USB socket which the device connects to so you either use that or a USB socket on another device.
Offline Matir
    • SystemOverlord
« Reply #5 on: May 06, 2017, 10:45:55 pm »
So say you have this USB hub:
It has both a USB input that supplies +5v, and a power brick that can supply +5V.  This is the two-source situation I'm describing.
Offline Matir
    • SystemOverlord
« Reply #6 on: May 06, 2017, 10:47:54 pm »
How can you power a downstream device after the diode drops?  At the input to hub you're getting 5V on a good day, after a diode drop, what, about 4.7 if you're bothering with Schottky diodes?  Add in USB cables and you have a lot of loss...
Online Zero999
  • 0999
« Reply #7 on: May 06, 2017, 11:01:18 pm »
What sort of connector does the power brick have? Do you have a picture of said connector?
Offline Matir
    • SystemOverlord
« Reply #8 on: May 06, 2017, 11:07:36 pm »
Not for this particular one, but all the ones I have seen have a plain barrel connector (often a typical 5.5 x 2.1mm, or sometimes a very small one).
Online KE5FX
    • KE5FX.COM
« Reply #9 on: May 06, 2017, 11:10:53 pm »
You typically use a MOSFET with a suitably low Ron.
On the demand side, it's a mistake to think of USB as a "5V" source.  You need to assume you might get as little as 4.3 to 4.5V from anything associated with USB.  Boost or SEPIC regulators can be helpful to avoid brownout problems.
Online Zero999
  • 0999
« Reply #10 on: May 06, 2017, 11:27:48 pm »
I haven't seen that before.
What voltage is the power brick? It wouldn't surprise me if it has a higher output voltage than 5V.
Offline sleemanj
  • Professional tightwad.
« Reply #11 on: May 07, 2017, 12:54:24 am »
If it's a cheap chinese hub, the external input will probably be directly connected with no provision for preventing backfeed.  I also suspect it's not really an issue, as long as you don't accidentally shove >5v into it's power.
In any case, this is one of those problems that sounds like it should have a really simple solution... but in practice it's really tricky (if you can't just use a diode and live with it's forward voltage and dissipation) for all sorts of reasons.
There are dedicated power management IC for this sort of job, eg TPS2115PW (no particular experience or reason for citing that one, just the first that I picked off the category list at RS).
Offline Matir
    • SystemOverlord
« Reply #12 on: May 08, 2017, 04:59:38 am »
For anyone following along, I happened to watch EEVBlog #643 tonight and discovered the TI TPS2113A, which is an "Autoswitching Power Mux".  This does exactly what I described (seamlessly switch between power inputs without backfeeding) and has an rDS (on) of ~84 mOhm.  At 1 A, that's a tiny .08V, instead of the (comparatively) massive voltage drop of a diode.
