Author Topic: Powering a PC SATA Power Conenctor  (Read 725 times)
Offline DW1961Topic starter
« on: May 25, 2021, 12:39:55 am »
How would I g about powering an SATA power connector using a bench power supply?
What I want to do is power a 5V LED controller so I can test computer ARGB lights before installing them. Unlike 12V RGB lights, which just require  + and -, the ARGB requires a signal to turn them on. So, I have to get a cheap controller, and then power it. All of the controllers HAVE SATA connector. I don't have a problem just cutting the SATA connector and using a + and - connection from the bench power supply, if that is all that's needed.
Controller: https://www.amazon.com/StepOK-Controller-Splitter-Plastic-Lighting/dp/B0899VYB16/ref=sr_1_3?dchild=1&keywords=5v+argb+controller&qid=1621903172&sr=8-3
Offline macboy
Re: Powering a PC SATA Power Conenctor
« Reply #1 on: May 25, 2021, 12:59:04 am »
Connect negative to the black wires and +5V to the red. If you need 12V, that's the yellow.
« Reply #2 on: May 25, 2021, 03:14:56 am »
SATA has 12V lead? What uses that?
« Reply #3 on: May 25, 2021, 09:16:32 am »
Older SATA 3.5in drives use the 12V supply, though more modern ones do not. SSD drives use 5V only, and pretty much nothing uses the 3V3 supply, deriving it from the 5V rail instead. Optical drives also use 12V.
The following users thanked this post: DW1961
Online mariush
« Reply #4 on: May 25, 2021, 01:54:42 pm »
Get a basic  molex to sata adapter cable, cut the molex connector and connect the wires to your power supply. Example cable : https://www.amazon.com/12in-SATA-Power-Cable-Adapter/dp/B0002GRUV4/
You only need the 5v and 12v wires ... red is 5v, yellow is 12v. Blacks are ground or negative.
Offline Monkeh
« Reply #5 on: May 25, 2021, 03:08:04 pm »
Rubbish. 3.5" drives almost if not entirely exclusively use the 12V rail for the spindle.
The following users thanked this post: amyk
« Reply #6 on: May 25, 2021, 05:12:27 pm »
HA!
It's been so long since I used a mechanical drive, I'd forgotten about the 12V sata purpose!
« Reply #7 on: May 25, 2021, 05:14:41 pm »
Could I  just cut one side of an SATA connector off and use the + and - wires with the power supply alligator clips?
