Author Topic: Powering an ESP32  (Read 4068 times)
Offline paulcaTopic starter
Powering an ESP32
« on: July 23, 2019, 06:07:05 pm »
So apart from tonight bench work being rather disappointing in that everything worked first time, I have a conundrum.
I'm using an ESP32 to run some WS2812 LEDs.  144 of them in fact.  The WS2812 run on 5V and take a 5V signal of around 1Mhz.  The ESP32 however is a 3.3V device.
Having read a bit about this, I bought a 74 series TTL bus transceiver which has a suitably low logic trigger voltage and emits Vcc.  Running it on 5V and feeding the 3.3V signal into it and 5V signal comes out, and it's fast enough to level shift the 1Mhz.
So when I wired this up, it all worked, annoying the LEDs worked with the 3.3V signal, but that might not be reliable.  First time I wired up the bus transciever on the breadboard and it also worked.  Checked with a handheld scope and could see rougly 3.3V going in and 5V coming out.
The conundrum is in powering the ESP32.  It will run from USB 5V of course and has a 3.3V regulator.  It also has a Vin pin.  Here's the catch.  The Vin pin takes 7-20V.  Giving it 5V and the device does not start.  How dumb is that?  Why not just put a pin on the USB power and allow it to run from 5V?
So either there is a 5V pin I'm missing or I'll have to use a boost converter to get 7+ volts or... I hack the board... or I use a USB plug to power it.
It's intended to be hidden inside an IKEA floor lamp with the LEDs running up the middle.  I have a beefy 10A 5V brick to power it.  The LEDs claim 60mA max each, so that's around 8Amps, but I have yet to provoke them to pull more that 5Amps.
Online langwadt
Re: Powering an ESP32
« Reply #1 on: July 23, 2019, 06:24:25 pm »
which ESP32 board?
« Reply #2 on: July 23, 2019, 06:26:31 pm »
It claims to be an ESP32 DevKit V1, though I'm not sure as the Board that works in Arduino IDE is actually the NodeMCU-32S
https://www.amazon.co.uk/JZK-ESP-32S-Development-Bluetooth-Antenna/dp/B071JR9WS9/ref=sr_1_1?crid=RDFOZTVU1M0N&keywords=nodemcu+esp32&qid=1563906555&s=gateway&sprefix=NodeMCU%2Caps%2C138&sr=8-1
So this seems to depend on what board you get.  Powered with 5V from it's VIN pin may not boot the MCU properly in many cases.
https://github.com/nodemcu/nodemcu-devkit-v1.0/issues/9
So I either buy a different dev board or I start hacking a USB plug to power it.  Shame.
In my case it took me to put 7V on the pin before it booted, although once booted it would run down to 5V or even 4.5V before browning out.
« Last Edit: July 23, 2019, 06:29:54 pm by paulca »
« Reply #3 on: July 29, 2019, 06:44:11 am »
Well, in the end I figured the onboard voltage regulator must be dropping the 5V to 3.3V and measured across it while running off USB and lo and behold, it was 4.89V and 3.27V, so ... I just soldered a mod wire onto the voltage regulator from my 5V supply and... the board powers up fine.
I still have no idea what they were thinking, or how they even managed to make the Vin pin require 7V-20V.
