Author Topic: Negative output from a boost converter  (Read 929 times)
Offline mcdescaTopic starter
« on: November 08, 2015, 10:09:37 am »
Hello,
Is it possible to obtain a negative output from a dc/dc boost converter by just reversing the output rails? Why is then an inverter mostly used in LCD bias?
Thanks.
Best,
Offline ruffy91
Re: Negative output from a boost converter
« Reply #1 on: November 08, 2015, 11:45:49 am »
Yes it is possible. But if it is not galvanically isolated you will not have GND as common but the positive DC/DC output and GND will be your negative output.
